Author Topic: Blinker won't blink  (Read 1298 times)
Offline GrandRapids750K3
Blinker won't blink
« on: March 20, 2011, 05:45:52 AM »
Got a question.
I have a 73 CB750 and the blinkers won't blink. I'm sure it's common knowledge to many, so I'm look for a little help.
I appreciate it!
Offline RatBikeRandy
  • Yes I Can
Re: Blinker won't blink
« Reply #1 on: March 20, 2011, 05:50:24 AM »
Probably the flasher. Mine was under the left side cover.  By the way, take it with you to auto parts store and you can match the same style connections.  I bought a replacement for less than $5.00 instead of $25 from Honda dealer.  It doesn't look exactly the same, but works fine.
« Reply #2 on: March 20, 2011, 06:00:49 AM »
That's what I was thinking. I have the left side cover pulled off, but am not sure what I'm looking for. Can anyone give me a description or a specific location? I also have a couple repair manuals, is the called something other than a flasher? Anything will help...size, color...
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #3 on: March 20, 2011, 06:18:31 AM »
GR,
They are also called winkers.  If you still have the original, it's a smallish rectangular metal can, maybe a half-inch bu 3/4 inch.  Connected wires are BLACK and GRAY.
There are a few other things you should check first. Did you replace turn signal bulbs when it stopped working?  If yes, chances are you put in the wrong ones.  Are your electrical connections all clean and tight?  If not, you may be loosing some voltage across bad joints thus reducing the current flow through the winker such that it won't heat up enough to flash.
You may wana replace your winker anyway.  If you do, look for a 3-prong electronic replacement.  You will find an unused GREEN (ground) wire floating behind the stock winker. Connect the green wire to the new flasher's GROUND or (-), the black to BATT or (+) and the gray to LOAD.  An electronic flasher unit with 1/4 inch male blade connectors would slip right in!
As a side note, I'm the 2011 World Tour/Relay coordinator for Michigan and I'm looking for riders in the GR area.  If you and your buddies are looking to ride with fellow SOHC4 riders, send me a PM and I'll fill you in!
« Last Edit: March 20, 2011, 06:29:42 AM by OldSchool_IsCool »
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #4 on: March 20, 2011, 06:26:08 AM »
Frequently dont work unless the engine is running and at over 3,000 rpm
Offline Johnie
« Reply #5 on: March 20, 2011, 06:31:48 AM »
Located between the battery box and the plastic false rear fender. Pics should help you out. Click pic to enlarge it.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #6 on: March 20, 2011, 10:50:26 AM »
Thanks everyone for the help. Ran out and picked up a new flasher from NAPA and I now have working blinkers. One of many projects crossed off the list.
Offline Johnie
« Reply #7 on: March 20, 2011, 10:55:07 AM »
What was the part number of the electronic 3 prong replacement you got from NAPA. I like that idea and will do it for my K4.
Oshkosh, WI  USA
