Author Topic: Front wheel install / question about speedo pickup  (Read 1132 times)
Offline kpier883
  • is quite the
« on: March 20, 2011, 03:41:01 PM »
I was installing the front wheel today and am reminded that the speedo pickup unit is free to spin around the axle until the speedo cable is hooked up.
Is that the way it is supposed to operate?
To phrase another way, the only thing that really keeps it from spinning round all the time is the cable itself.  Have I assembled it improperly?  The Clymer manual offers no help.
1974 CB750.
Hopefully this link will work.  This is a short video of the wheel demonstrating how the pickup is not held in place.
http://s1080.photobucket.com/albums/j338/junk883/?action=view&current=CB750Front1.mp4
And this is to demonstrate that it still moves after installing and tightening the wheel.  The only thing keeping it from spinning around is the cable itself:
http://s1080.photobucket.com/albums/j338/junk883/?action=view&current=CB750Front2.mp4
« Last Edit: March 20, 2011, 04:20:28 PM by kpier883 »
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
Re: Front wheel install / question about speedo pickup
« Reply #1 on: March 20, 2011, 04:21:35 PM »
Mine too. I assume it's normal...or,..hope.
Online Johnie
« Reply #2 on: March 20, 2011, 05:01:34 PM »
To be honest, my K4 does not move once the axle has been tightened to spec.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #3 on: March 20, 2011, 05:15:14 PM »
Your first video is correct. Once the axle nut is tightened down, the speedo drive becomes one with the axle. It is part of the "spacer stack" that runs thru the hub.
The second video presents a problem. Once the axle is clamped in the lower legs, the speedo drive should be locked in place, as the axle is locked in place. That is why you have to make sure the drive is pointing back and level as when the axle clamps are tightened it cannot move.
Or at least its not supposed to.
Offline kpier883
  • is quite the
« Reply #4 on: March 20, 2011, 06:56:50 PM »
Hmmmm.  I'll keep looking at it.
Thanks for the replies.  Keep 'em coming please.
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
« Reply #5 on: March 20, 2011, 07:02:11 PM »
I did go out and checked my K2 just to be sure, and it is locked in place.
