Author Topic: 77 cb 550 timing  (Read 1707 times)
Offline blackfire
77 cb 550 timing
« on: March 22, 2011, 06:32:08 PM »
I have the head back on the bike and can't figure out how to get the timing chain back on the cam gear.  I have read on how to time the bike, but advice would be helpful from those who have done this before.  I am new at this and it has been a fun experience but wouldn't do it again.  thanks matt
Offline MADCB400F
  • My 74 CB750
Re: 77 cb 550 timing
« Reply #1 on: March 22, 2011, 06:38:37 PM »
Hi, when you look at the cam sprocket you will see diffrent size cut outs in the middle. Find the one that is the closest to the edge and put that at the top. Make sure your tension adjuster is not installed. Work the chain onto the sprocket. Once there move sprocket one link at a time until the marks line up per your doc. Hope that helps.
« Reply #2 on: March 22, 2011, 06:45:16 PM »
I believe there is a "how to" in the engine FAQs also.
Offline blackfire
« Reply #3 on: March 22, 2011, 07:32:13 PM »
guess the tensioner is coming back out.  thanks much.
Offline Roach
« Reply #4 on: March 22, 2011, 08:13:38 PM »
don't take the tension-er out!!
all you need to so is
tighten up the tensioner so it doesn't put any force on the chain
slide the cam under the chain going from left top right from cylinder 1-4 slide on the sprocket
move the sprocket down to where it bolts up on the cam...
before you bolt it on make sure the grove in the end of the cam is in line with the top edge of the block..drop the cam down onto its seat bolt the sprocket to the cam loosen off the adjuster and use the elastic band trick to put cover back on.
1978 CB550K Cafe Racer
Offline daytonajoker
« Reply #5 on: March 23, 2011, 04:18:01 AM »
What's the "elastic band trick" ?
Offline Roach
« Reply #6 on: March 23, 2011, 11:45:57 AM »
it gets the tappet cover back on without binding on your valves  look it up in tricks and tips
its a matter of running rubber bands over the valve cover
http://forums.sohc4.net/index.php?topic=82508.0
Offline blackfire
« Reply #7 on: March 27, 2011, 05:39:26 PM »
Thanks for all the advice along the way.  I have it all back together and was going to time the bike.  the 2-3 mark is in alignment, so is 1-4 also aligned?  the cam notch is level with the head surface.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: March 27, 2011, 05:59:43 PM »
If you turn your crank to the 1-4 T mark the cam notch should be aligned to the head deck. Your cam is 90 degrees off which means your crank is 180 degrees off. Download the manual and read it. The is a certain method and order to installing the cam sprocket and chain and it works.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
