Author Topic: Head cover removal for CB 750  (Read 1959 times)
Offline anotherCB
« on: March 23, 2011, 06:55:49 AM »
I need to remove the head cover (not head) of my 1977 CB 750. Can I do that with the engine in the frame? At this point I have no intentions to remove the head, just have a bad seal where the tach connects and also want to take a look at the cam, since I just picked up the bike and it has 37,000 mls on the clock. Thanks.
1978 CB750K, 2016 R1200 GS/LC, 1973 R75/5
Offline MoMo
  • Ride like you're invisible
Re: Head cover removal for CB 750
« Reply #1 on: March 23, 2011, 06:59:53 AM »
Unfortunately, no...Larry
« Reply #2 on: March 23, 2011, 07:04:17 AM »
Photolar is correct.
That tach drive seal can be replaced from the outside, and...your cam is OK.   :)  Honestly, the cam is good for 100,000+.  I would pull the little tappet adjuster screws and check them for pitting, or wear.  They do wear and make it difficult to get a good valve adjustment reading.
Offline anotherCB
« Reply #3 on: March 23, 2011, 07:20:21 AM »
Ok great, that saves me some work  :) Allthough I really wanted to take a look inside....Are there good instructions somewhere on how to check the cam chain tension and/or how to adjust it?
« Reply #4 on: March 23, 2011, 07:26:22 AM »
Plenty, either Google the Internet or Search this site. Hint: go to "Home" on the blue forum menu bar first. Then search CB750 cam chain tension, or somesuch.  Also there is a link to download manuals, and its covered there. I'd tell you but gotta sign off for a while.
