Author Topic: broken stud. part discontinued. arrggg!  (Read 1389 times)
Offline ultragoat
« on: March 23, 2011, 04:14:23 PM »
So I'm putting my '78 750 motor back together. All is going well when I begin torquing down the cylinder head and then I hear the dreaded *SNAP* on the long 6X90 flange bolt. I get it out okay and go order another one from the local Honda shop. A week later I get it and get everything torqued down without any problems.
Then, I'm almost almost finishing putting the cam towers, camshaft etc. back together when I hear it again: SNAP! (note to self: get a better-than-harbor-freight torque wrench  :-[) This time the victim was one of the 6X58 studs that holds the cam tower to the head.  Now here's the problem: Honda had discontinued this part. I guess I could try and cut down a stud if it's similar. I'm also gonna take a trip out to the motorcycle graveyard tomorrow and see if they can help.
Other than that, does anyone know where I might possible find one of these suckers?
That's the most foul, cruel, and bad-tempered rodent you ever set eyes on!
Offline Gaither
  • '77 CB550F
Re: broken stud. part discontinued. arrggg!
« Reply #1 on: March 23, 2011, 06:38:25 PM »
Perhaps a local fastener supplier could match it up - including hardness [?].
You could ask in "parts wanted". Somebody has one.
Gaither ('77 CB550F)
Offline Leanier
« Reply #2 on: March 23, 2011, 09:19:29 PM »
I actually did the same thing as you when putting my engine back together, couldn't find the stud anywhere, so what I ended up doing is finding a bolt with the same thread that goes into the engine, and cutting off the head, and buying a die that matched the thread of the nut, and making my own stud.  worked great! pretty cheap overall to, especially if you own the die already (which i didnt)
My motorcycle collection thus far:
'74 CB360
'73 CB750
'72 CB125s
'68 CA160
Offline rangelov
  • The Dual Disc Conversion Speedometer Driver
« Reply #3 on: March 23, 2011, 09:35:58 PM »
A 6mm long bolt isn't exactly a structural member.  Make your own.  On some thing that small you should using an inch pound torque wrench.
Or better yet, don't use a torque wrench, do it by feel.  If you do enough 6mm bolts and studs, you can tell when they are tight enough, starting to strip, or about to snap.
A bad torque wrench, wrong scale, or incorrect published torque will get you in trouble.
Develop that feel, it might have saved this aggravation.  I don't think 6 mm screws should be torqued, especially when threaded into soft aluminum.
http://forums.sohc4.net/index.php?topic=76835
CB750K4, Boss maroon metallic, 836cc, RC Engrg 4 into 1, Forks by Frank, air assisted front forks,  JC Whitney 16" rear.
Offline scunny
  • don't call me expert
« Reply #4 on: March 23, 2011, 11:07:24 PM »
my GS1000 loved to break the cam tower bolts after a rebuild, bought new ones and no problem. must be made of jelly
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline ultragoat
« Reply #5 on: March 24, 2011, 08:06:43 AM »
Update: My local Honda shop said they could order some studs that are 2mm longer (6X60) that are meant for a different engine/manufacturer so we'll see if those work (fingers crossed). I'll go a little easier on the torquing this time. Thanks for all your suggestions.
