Author Topic: '76 550 hub question  (Read 858 times)
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« on: March 24, 2011, 02:30:36 PM »
I am in the process of rebuilding the rear hub, and I am wondering if ascertain piece come off or not. The photo below, from top to bottom, shows a shiny hollow cylinder, and then a rubber o-ring/gasket, and then the duller, main part of the hub.
My question:  does this shiny cylinder come off?  It doesn't seem to want to budge, but I would assume that the o-ring can be replaced???
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
Re: '76 550 hub question
« Reply #1 on: March 25, 2011, 05:40:28 AM »
No.
Yes. Part # 91261-323-000 [79x2.6]
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #2 on: March 25, 2011, 05:54:26 AM »
Thanks Frosty.
Would I buy a new o-ring, and just pull it around to replace it.  It looks to be in fine condition, so this may be unnecessary.  But without taking it off and looking at it closer - I wasn't sure of it's role and it's true condition.
~Sophocles
Offline Frostyboy
  • Circa 1951
« Reply #3 on: March 25, 2011, 06:00:57 AM »
Yep, if you want to replace it, the new one will stretch easy enough to go down there. By the look of it though it's doing it's job of keeping dust out of the area where the drive flange moves on the hub for the cush drive to do its job.
Maybe no need to change it at all, just keep high powered solvents away from it if you are going to clean it that way.
We haven't met yet.
[CB550F1]
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #4 on: March 25, 2011, 06:05:04 AM »
Perfect!  Thanks again.
~Sophocles
