Author Topic: Vintage CR31 Carbs  (Read 3628 times)
Offline H2Eric
Vintage CR31 Carbs
« on: March 26, 2011, 10:08:57 AM »
Some of you CR gurus out there must have come across this problem.
I acquired this set of carbs from Kurt Liebman some time ago, the accompanying inlet rubbers came from a different source. The rubbers fit nicely on the carbs though I may have got the things on the wrong way round in the pic, but subsequently removed. The rubbers have no numbers on them like the standard items, just a letter A, B, C, and D. The snag is that the inlet rubbers don't fit the inlet stubs on the back of the cylinder head because they are simply too big. Hmm, something definitely amiss here. Is there a simple solution or have I got the wrong parts?
Thanks
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
http://forums.sohc4.net/index.php/topic,94588.0.html
Growing old is mandatory, growing up is optional.
Offline kmb69
Re: Vintage CR31 Carbs
« Reply #1 on: March 26, 2011, 10:44:18 AM »
Maybe for the F2 head? If you want to sell them and get you some proper inlet manifolds, let me know.
Keith
Offline voxonda
« Reply #2 on: March 26, 2011, 11:09:13 AM »
Looks like they are intake rubbers for a DOHC 750, they used the same CR31's. And their spigots are bigger.
Rob
Offline lordmoonpie
    • Moonpie
« Reply #3 on: March 27, 2011, 05:38:15 AM »
I used standard manifold rubbers on my CR31s - they are a total bugger to push on the stubs but once on they are fine...
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline H2Eric
« Reply #4 on: March 28, 2011, 01:20:04 AM »
Keith
Thanks Keith
PM sent
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
Offline kos
    • m3racing.com
« Reply #5 on: March 28, 2011, 01:33:29 PM »
Looks from picture that carb spacing is uneven IE:  distance between 1 & 2 is not same as between 2 & 3.  If that is case those are CR900 carbs which are made original for Z1 Kaws and then later fit same spacing on Suzy 750/1000"s as the Suzy motor was a copy of Z1.
If those rubbers were from DOHC, they would be huge and not even come close to fitting.
If carbs are CR900 you need Mikuni 29 smooth bore rubbers and I have those in stock.
Mark @m3
KOS
220...221, whatever it takes.
Offline voxonda
« Reply #6 on: March 28, 2011, 01:40:51 PM »
Mark,
Would the 29 smoothbore rubbers fit the VM33's?
Thanks, Rob
Offline H2Eric
« Reply #7 on: March 28, 2011, 02:58:02 PM »
Mark @m3
KOS
Mark
Well spotted, the spacing is uneven just as you say. Will the Mikuni 29 smooth bore rubbers line up with that uneven spacing or do the carbs have to be adjusted to make the spacing even, which doesn't look easy at first glance.
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
Offline kos
    • m3racing.com
« Reply #8 on: March 28, 2011, 03:10:49 PM »
Yes, The Mikuni manifolds make the uneven spaced carbs line up and work just perfect. Bolt on and these are new!
Mark  @ M3
Offline kos
    • m3racing.com
« Reply #9 on: March 28, 2011, 03:45:28 PM »
Mark,
Thanks, Rob
Well, they fit the  KO head from 1969-1976 and have the same spacing as kaws an suzukis, Spigot size is same as 31mm early keihin race carbs (34mm  inlet side of carb) so the rest is up to you as I  do not ever use Mikunis.
KOS
