Author Topic: Headlamp swap, wiring question, white/blue/green now red/yellow/black ??  (Read 731 times)
Offline eworth
Hey all,
This will relieve a bit of concern on my project if you all could confirm my headlamp swap which now is a bit different.
My 1977 CB550F headlamp stock is:
White= low beam
Blue  = high beam
Green = ground
New headlamp from a chinese chang jiang has the following headlamp wiring colors:    RED , YELLOW and BLACK
WHICH IS low, high and ground on the new headlamp....   This is to be sure before I accidentally "let the smoke out" of the wires.
Appreciate your help!!
Thanks,
Eworth
Offline eworth
figured it out.
Offline Kong
Look at how they come out of the plugs, that will give you the match.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline eworth
Well, I thought that would be also.   But wasn't the case in my case with the Chinese Headlamp assemble from a Chang Jiang.  All is well.  Hooked everything up to a battery and tested with a toggle switch before installing /' re-labeling my colors to make sense of it.
