Author Topic: Aftermarket fuel caps  (Read 7590 times)
Offline q2418130103p
« on: March 27, 2011, 08:16:56 AM »
So I bought a new tank for my project bike which requires one of the honda flip-up type caps.  I dont have one of these, so I would have to purchase one.  But for certain reasons I have been thinking about replacing it with a completely different cap.
Specifically I was thinking of using a more modern, flush mounted, fuel lid.
Something like this, but it doesnt have to be.  A more subtle, pop up type cap like the second picture, may be better:
Here is the kicker though, I need to find one that comes with its own metal base which can be welded to the tank as opposed to welding nuts to the inside of the tank.  Granted, I could make this, but I would rather not.
« Last Edit: March 27, 2011, 08:19:15 AM by q2418130103p »
Check out my CB550 project thread:
http://forums.sohc4.net/index.php?topic=83097
Offline Ricky_Racer
Re: Aftermarket fuel caps
« Reply #1 on: March 27, 2011, 05:40:58 PM »
Newton caps have a 3/4 circle inside the tank plate that takes the mounting bolts of the Aero cap assembly. You can get the caps from Dennis Kirk, but you'll have to make the 3/4 circle or try to get one from England.  RR
« Reply #2 on: March 27, 2011, 06:51:45 PM »
Those are great, I am looking into those pieces right now.  I am going to assume they are rather expensive.  I am currently trying to figure out what actually comes in each kit.
I think either the Aero 200 or the similar 'Zero' range unit, which has a key.
http://www.newton-equipment.com/a2ns.html
They say that unit comes with a weld in neck, but I havent been able to find good pictures yet.
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
« Reply #3 on: March 27, 2011, 07:24:14 PM »
I just don't know why you'd want an airplane style filler cap on a Honda motorcycle.
That said, Carpy makes this one:
Joker Machine sells these (raw or anodized black):
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
« Reply #4 on: March 27, 2011, 08:17:49 PM »
I like flush mount.  However, the ones you posted are very nice, and I imagine cost a lot less than a Newton.
« Reply #5 on: March 27, 2011, 10:53:09 PM »
 Saw a NICE  flush ONE a few hours ago..
 CUSTOM CYCLE ENGINEERING I think made it...
« Reply #6 on: March 28, 2011, 04:05:26 AM »
They have some nice stuff, and their prices arent too bad either:
I dont really get how that first one is meant to be mounted though.
« Last Edit: March 28, 2011, 04:07:25 AM by q2418130103p »
Offline swellguy
« Reply #7 on: March 28, 2011, 07:23:36 AM »
This part gets welded onto your tank:
« Reply #8 on: March 28, 2011, 09:18:50 AM »
 I saw the lower one, it was very clean and flush, and the cap goes in 4 ways. It was on a very slick v-twin that is getting ready for Bonneville.
 I think the split mount one is for getting inside the tank, if the tank is already built.
« Reply #9 on: March 28, 2011, 10:46:42 AM »
Thats what I was thinking two.  I think the second unit needs to be welded from the inside, which I cant do, but the first unit (plit ring design) is what I need.  Does anyone know why the ring is split?  I am guessing you are supposed to cut a hole which is slightly smaller in diamter than the ring is, so you need it split in order to get it inside the tank.
Offline Silverback
« Reply #10 on: March 28, 2011, 10:56:26 AM »
Yep, the split ring is a "no-weld" version. The gasket goes in between the top part and the tank and is clamped in place. The split pieces go inside the tank. Tricky to install, but a good no-weld solution. I was looking for a weld-in flip top myself, but may go with aircraft style posted, or cut one out of a Honda tank.
I like the look of the Carpy piece, but it requires a flat surface.
« Last Edit: March 28, 2011, 10:58:12 AM by Silverback »
Chris
"It's hard to define soul. You get it in art. You get it in music, and occasionally you get it in machinery."
78 CB750F racer
78 CB750F stock
75 CB750K Baby Blue Sold (She was a great bike!)
71 CB750K (rusty rod)
77 cb550F Sold :(  Bought it Back :)
Basket case 73 CB750, 77 CB750F (Building now)
01 Aprilia Falco
76 kz400
96 BMW K1100LT
« Reply #11 on: March 28, 2011, 11:22:42 AM »
Well I would like a weld-in, as long as it can be welded from the top.  But A bolt on solution is nice and simple...    But with the bolt-on you would need a very flat surface, and with the weld-in you could get creative with the weld in order to get it in a slightly rounded surface.
Also, I assume vented is required, as opposed to non-vented. Correct?
Offline Ricky_Racer
« Reply #12 on: March 28, 2011, 02:41:40 PM »
« Last Edit: March 28, 2011, 02:48:09 PM by Ricky_Racer »
Offline juice
Daily driver: SV1K 2003
In the works: CB550K 1978
« Reply #14 on: March 28, 2011, 04:11:41 PM »
lol, nice.  That happens all too often.
I am getting really tired of seeing "Made Exclusively for..." or "A [blank] original", only to find the same product online, from its Hong Kong dealer, for 1/4 of the price.
« Reply #15 on: April 05, 2011, 03:27:45 PM »
Do I need a vented or non-vented cap.
I assume vented, since I dont know of any other vent for the tank...
« Reply #16 on: April 05, 2011, 05:04:46 PM »
Just FYI. http://shopping.rexmar.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=463151&Category_Code=fuelfillsfliptop Does this look familiar to anyone???     ;D  RR
Nice find RR.... ;)
I have the black Joker machine cap and it is very nice.....
Offline Silverback
« Reply #17 on: April 05, 2011, 05:13:49 PM »
Vented, fo sho!
Chris
78 CB750F racer
78 CB750F stock
01 Aprilia Falco
76 kz400
96 BMW K1100LT
« Reply #18 on: April 05, 2011, 05:44:58 PM »
Thanks
Offline mrrch
my build
Offline johnny
« Reply #20 on: April 06, 2011, 06:40:34 AM »
Anyone try one of these?
http://tinyurl.com/3rnv88u
1976 CB550K
1974 CB350F http://forums.sohc4.net/index.php?topic=81781.0
1974 CB550K
1972 CB350 Twin
1965 Lambretta
196(?) Honda S90
1975 Ford Bronco
« Reply #21 on: April 06, 2011, 07:07:54 AM »
snip
My 1988 Honda HawkGT has a flush filler cap. Not quite a 70s part, but it does make a nice surface for a tank bag.
« Reply #22 on: April 06, 2011, 07:42:56 AM »
I like them because they are clean.  The tank I am using is already hugely tall, so another 1.25" off the top of the tank is really high.
Plus there is some putty work I'd like to fix near the current bung, which would require a lot of work anyway.
I have nearly finished deciding on the 2-1/4" bolt on, vented, non-locking, setup from custom cycle engineering.  Currently I am just debating on whether the top of the tank is flat enough to mount the 3-3/4" outer ring.
Offline Silverback
« Reply #23 on: April 06, 2011, 07:52:59 AM »
Ha ha! I like what is says on his website. "OK, many people have asked about my Cool gas cap, so I thought about it and have now made it available for your very own CAFE RACER creation."
Glad that "he" has made it available for all of us. He is so gracious!
Chris
78 CB750F racer
78 CB750F stock
01 Aprilia Falco
76 kz400
96 BMW K1100LT
« Reply #24 on: April 06, 2011, 07:57:30 AM »
They are a period accessory, though I think those are reproductions. Anyway, consensus is they are not very accurate, finish doesn't hold up well, the lens cracks and yellows, the weight bangs around in the tank to where you can hear it. Etc. You asked.   :D  PS: Not from personal experience, just what I've read. YMMV   OCICBW
« Last Edit: April 06, 2011, 07:59:18 AM by MCRider »
