Author Topic: Green Hornet CB 550/650 # Some pics of my trip to Scotland with SOHC4 Honda  (Read 80274 times)
0 Members and 8 Guests are viewing this topic.
Offline Oette
Re: Cafe Racer CB 550: Building diary #welding brackets for rearsets?
« Reply #100 on: July 09, 2012, 11:41:11 am »
Had some time today to regrind the frame's rear end. After finishing it to my satisfaction I welded and shaped it.
Have a look at the results: In my opinion the first impression is not as bad as I thought first.
Edit: Just recognized that I uploaded the wrong pic. Welded ends just have the same shape. If someone is interested, I'll post a pic later.
« Last Edit: July 09, 2012, 11:44:50 am by Oette »
Offline tortelvis
Re: Cafe Racer CB 550: Building diary #shaped frame
« Reply #101 on: July 10, 2012, 08:19:18 am »
Pro:
They look cool
Con:
Suck dirt and particles into your motor
Designed to run wide open on race motors not at idle.
Thats my main points.
Maybe so, but I ran an XS1100 for over 5 years with homemade velocity stacks and as far as I know the guy that bought it is still running with them.
Offline Syscrush
  • Sold. :(
« Reply #102 on: July 10, 2012, 01:23:41 pm »
Saw a CB 750 today with a nice set of velocity stacks. After a quick search on that topic it says, that these would go along well with some porting work.
Have you looked at TinTop's stack/filter combo?
I would never run a motor with no air filter.  Even if it's someone else paying for motor rebuilds, modern filters are so efficient, why accept the risk?
Offline Oette
Re: Cafe Racer CB 550: Building diary #Got rearsets / kickstart clearance
« Reply #103 on: July 14, 2012, 07:28:50 am »
Hi guys,
need you help with some thoughts.
I'm stuck with the popular problem, the kickstarter lever vs rearsets clearance.
Read many threads about this problem here in the forum and finally had 2 ideas concerning that.
First, the CB 550 F kickstarter offers a bit more space to work with. I thought of treating it with some heat to bend it about a half inch more away from the frame (if necessary).
Second, someone talked about using a CB 750 kickstart lever. Does it work?
Regards,
Oette
Offline Tews19
  • I am no
Re: Cafe Racer CB 550: Building diary #kickstarter vs rearsets...
« Reply #104 on: July 14, 2012, 08:51:38 am »
Check this build out. You can see how he modified the lever.
http://forums.sohc4.net/index.php?topic=97338.0
1970 Honda CB750 survivor.
Offline Oette
« Reply #105 on: July 14, 2012, 03:56:23 pm »
The problem is, my rearsets are not foldable... And I am using the passengers footpegs, too, so there is no option to mount them on the passenger footpeg's brackets.
Offline Oette
« Reply #106 on: July 14, 2012, 04:08:52 pm »
From another forum there was another suggestion: Use a kickstarter from a CB 450 K which should be shorter...  Does anyone have information if it fits the 550?
Offline Oette
« Reply #107 on: July 18, 2012, 12:43:57 pm »
Some progress over here
-drilled the frame to fit the electronic's box
-finished the seat's screw joint, it's now fastened with 3 knurled screw
Front:
Rear:
-Got alloy rims
Offline Mcwilliams570
Re: Cafe Racer CB 550: Building diary #seat joints finished/alloy rims
« Reply #108 on: July 18, 2012, 12:52:46 pm »
Looking good so far. What type of rims are those.
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline Oette
« Reply #109 on: July 18, 2012, 12:58:27 pm »
Matt
I'm sorry, but what exactly do you mean with the type?
Size? Width?
« Reply #110 on: July 18, 2012, 01:16:30 pm »
Sorry what brand is it..
Matt
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline Oette
« Reply #111 on: July 18, 2012, 01:19:59 pm »
No problem. It's made in Germany, brand is Behr Industries.
It's primary business field are motocross rims.
You can find it here (english version)
http://www.saxess-crossthelimits.com/index.php?id=51&L=1
Offline turboguzzi
« Reply #112 on: July 18, 2012, 02:31:18 pm »
nice.... but couldnt see any type of online catalog...  do they sell direct or only through dealers?
Danke
TG
Offline Oette
« Reply #113 on: July 18, 2012, 09:53:26 pm »
I got my rims via their outlet store. Unfortunately they sell through dealers, but maybe you can find some ?
Offline Oette
« Reply #114 on: July 23, 2012, 12:32:43 pm »
I'm in a great depression. Tried to work on the seat and everything seems to look like rubbish. Bothering myself about dents and mock-welds...  Wondering if its possible to powdercoat it. Sometimes I'm just about to throw the whole bike into the next bush. Know, that this will be a heavy throw   >:( :'(
Offline Syscrush
  • Sold. :(
« Reply #115 on: July 23, 2012, 12:52:39 pm »
Take a couple of days away from it.  Have a friend help you out the next time you're gonna go at it.  It'll help keep you focused on the positive.
Offline sinister902
    • Anger Street Kustoms
« Reply #116 on: July 23, 2012, 12:53:51 pm »
I feel your pain Oette......my build has been a 6yr up-hill battle of trying to get it a little closer to where I want it each year yet still be able to have it rideable for the season.....just found that I may have burnt up the piston rings after spending 2 months re-wiring the whole bike and fixing dents/paintwork..... bullocks.
keep at it. those days when the bike rides and looks the way you wanted are super worth it.
Offline Oette
« Reply #117 on: July 26, 2012, 06:23:59 am »
Hey guys,
need some experiences here.
Yesterday I started to cut my plastic front fender into the right shape. It's not finished yet, but I'll go on when I'm finished with its mounting brackets.
Since it wasn't a Honda fender, the original bracket did not fit into my fork. I made some aluminium brackets which still need to be cutted and filed into the right form. Moreover, the fender is not mounted as high as on the pics, the brackets still need to be bend, so the result is a height about 20mm over the tire.
But the point is: Do I need some connection between the brackets under or over the fender (bail?), or will it work just to rivet each bracket directly to the fender?
Pics:
Offline sinister902
Re: Cafe Racer CB 550: Building diary #fender question
« Reply #118 on: July 26, 2012, 06:29:53 am »
the original fender's mount went underneathe the fender and acted as a fork brace while simultaneously mounting the fender. I would reccomend doing something similar to aid in making the front end stable.
Offline Oette
« Reply #119 on: July 26, 2012, 06:35:27 am »
Does it have that much influence? These mounts are also just out of 2,5mm steel and easy bendable with one hand.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=t86qdjscm5mul4u2hvls0tl5t5&/topic,60973.0.html
« Reply #120 on: July 26, 2012, 07:30:16 am »
think you need a stabilisator between the legs..my cbx have one..its a must...and then the fender can be bolted on up in it..but think not that orginal fender holds so mutch..
« Last Edit: July 26, 2012, 07:34:45 am by strynboen »
i hate all this v-w.... vords
Offline Oette
Re: Cafe Racer CB 550: Building diary #forged alloy handlebars
« Reply #121 on: July 28, 2012, 10:06:01 am »
Got a tidbit today,
New forged alloy handlebars. Light as hell, very well manufactured.
Offline Syscrush
  • Sold. :(
« Reply #122 on: July 29, 2012, 05:46:13 pm »
Got a tidbit today,
Very nice! Is that renewing your interest in the project?
Offline Oette
« Reply #123 on: August 05, 2012, 07:27:07 am »
Got a tidbit today,
Definetly. Had my summer holidays last week and tons of ideas while laying at the beach.
Offline Syscrush
  • Sold. :(
« Reply #124 on: August 05, 2012, 07:42:47 am »
Glad to hear it!
