Author Topic: Green Hornet CB 550/650 # Some pics of my trip to Scotland with SOHC4 Honda  (Read 80507 times)
Offline Tews19
  • I am no
Re: Green Hornet CB 550/650 Hybrid Engine Mod //Video of testrun
« Reply #325 on: August 27, 2014, 10:46:38 AM »
Thanks for the input! Now please post a video of her on the country roads tearing up your neck of the woods!
1970 Honda CB750 survivor.
Offline Oette
« Reply #326 on: August 27, 2014, 10:50:02 AM »
Well, that'll take some days  ;)
« Reply #327 on: August 27, 2014, 11:13:24 AM »
Also does it #$%* as smooth as a 550?
I can only imagine . . .   ::)
Offline Tews19
  • I am no
« Reply #328 on: August 27, 2014, 11:14:54 AM »
Oh man. That's a funny auto correct. Lol
Offline Tews19
  • I am no
« Reply #329 on: August 27, 2014, 11:16:15 AM »
Laughing my ass off where I'm having tears build up.
Offline Oette
« Reply #330 on: January 07, 2015, 04:47:01 PM »
Made a highlight video of 2014, underlined by some matching music.
Check it out
YouTube
Vimeo
Not a valid vimeo URL
Re: Green Hornet CB 550/650 # Highlight video of 2014
« Reply #331 on: January 07, 2015, 04:51:03 PM »
Very nicely produced video!!  I love the runs through the forest.
« Reply #332 on: January 08, 2015, 04:29:05 AM »
Very nice!
Online calj737
  • I refuse...
« Reply #333 on: January 08, 2015, 04:47:19 AM »
February candidate for BOTM?
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #334 on: January 08, 2015, 08:18:06 PM »
Agreed.
Offline Tews19
  • I am no
« Reply #335 on: January 08, 2015, 08:22:11 PM »
Third that! Great video. At first I thought the song was from the new Tron opening  bike scene. I looked forward to the second installment!
« Reply #336 on: January 08, 2015, 09:45:51 PM »
Alright, let's transfer the nominations to the NOMINATION THREAD!
Online calj737
  • I refuse...
« Reply #337 on: January 08, 2015, 10:54:20 PM »
Oette - you need to pop over to the BOTm thread and accept your nomination (if so willing)
« Reply #338 on: January 09, 2015, 05:20:24 AM »
Somehow I remember Green Hornet was already in BOTM, but I may be wrong.
Offline Oette
« Reply #339 on: January 09, 2015, 05:39:22 AM »
Yes, it has been last May or so...
The video soundtrack comes from the Tron movie  :P
« Reply #340 on: January 09, 2015, 07:39:59 AM »
Oette was nominated WAY back for the November 2013 BOTM.  http://forums.sohc4.net/index.php?topic=130212.0
His bike qualifies under BOTM rule 4.  http://forums.sohc4.net/index.php?topic=8929.0
« Last Edit: January 09, 2015, 08:31:22 AM by CB750 Cafe Racer Fan »
« Reply #341 on: January 09, 2015, 02:37:39 PM »
Oette, Bike looks great! Love the color. So bold!
Can you clarify on your 650/550 hybrid...
Did you install the 650 crank and rods inside the 550 cases?
You mention the tensioner, that's the same bolt onto the case style Paulages did?
It is clear that you have transplanted the 650 top end (cylinder/pistons/head/tappet cover, etc.) onto the 550 cases, but just wanting clarification on the internals inside the cases.
I seem to recall the 550 cases had to be modified to fit the cylinder liners from the 650 along with lots of other things Paulages documented in his hybrid motor build.
Also, is it a stock 650 camshaft or did you have a more aggressive cam made or purchased for the bike?
Paulages also did a hybrid that was an Overbore on the 650 to boost the displacement to extreme measures. Did you go this route as well or just a normal overbore on the 650 in the rebuild in standard sizes.
Thanks!
David
« Reply #342 on: January 09, 2015, 03:00:26 PM »
Another question Oette on your tach modification. When riding at night, do you have the means to adjust the brightness of the LEDs.
Is it too bright?
Also, does the illumination of the Sigma bike speedo display visible at the edge of the tach or does the case hide them enough to not cause a bright spot that is dazzling.
The little surface mount LEDs can be blindingly bright.
Thank you!
David
Offline Oette
« Reply #343 on: January 09, 2015, 04:50:42 PM »
Thanks!
David
Thanks David,
Yes, it's a whole 650 system including crank and rods. I did not change the displacement since I had to cut the budget (student) so I went with the original pistons, which were in a good condition. When it's time for first overbore there may be some work concerning more displacement.
I am running a CB 550 cam regrind. Not absolutely sure, but it has a increased lift of about 1.6mm and slightly longer duration. Works good so far though I have had no visit at the dyno yet.
In case you want to put a 650 Cylinder on a 550 case, the only thing youll have to do when you use the 650 crank and timing chain is to add 2 slots for the chain tensioner, because its about 16 (?)mm apart from the 550's slot.
Some other changes are required at the ignition side, e.g the advancer pin to use the 550's ignition.
The primary chain tensioner was installed in a nearly equal setup and that is, without serious welding on the case, maybe the only proper solution to mount the tensioner in the 550's case.
Is it too bright?
Thank you!
David
2nd round for you, David,
The speedo is not too bright. Unfortunately all pics at low light intensify the lights of the speedo in the pics. You probably can make the brightness adjustable using an adjustable resistance placed on the outside of the gauge. But since it's perfectly enlighted for my eyes in the dark, I did not make that step.
So far it is not visible and everything is hidden behind the gauge face plate. The SMD LEDs behind the face plate enlight the display in a quite homogenous way.
« Reply #344 on: January 09, 2015, 07:51:27 PM »
Thank you Oette.
You have done a nice job on the bike. Classic German engineering attention to detail shows in your build.
Offline Oette
« Reply #345 on: January 12, 2015, 02:35:12 PM »
Thanks David, funny fact: Many details are a product of a sudden idea e.g. to integrate that digital speedometer came to my mind while I was out in the woods mountainbiking.
Offline Wredas
« Reply #346 on: March 11, 2015, 07:11:44 AM »
Awesome build! Just read the whole thread, great job! The bike looks amazing.
« Reply #347 on: March 11, 2015, 08:53:54 AM »
Excellent video! The roads remind of driving round the Eifel region near Cologne. Quick question what camera did you use for the video and what software to edit the video - very interested in trying this myself. Thanks and again great work I really like what you have done with the bike.
Headlight? I read through your entire build and may have missed it but what are you using for a headlight? Thanks
cheers
Andy
« Last Edit: March 11, 2015, 09:51:43 AM by andy750 »
Offline Tews19
  • I am no
« Reply #348 on: April 23, 2015, 06:11:41 AM »
Oette where is the new 2015 video??? How has the bike been holding up?
« Reply #349 on: September 16, 2015, 09:06:33 PM »
bump, Oette, are you there?
How's the bike and do you have any video or photos for us?
Thanks!
David
