Author Topic: Small Project - Repair and Paint Engine Guards  (Read 3721 times)
Offline kpier883
  • is quite the
« on: March 27, 2011, 05:35:56 PM »
Thanks to MyNameIsMudd I have have a pair of engine guards!  :)
Here are a few pictures of the process to strip and sand the rust, JB weld a few holes and get started painting.  I have some welding to do on one of them so it will be painted later.
First, one of them that has been soaked on one end in a diluted Jaso Metal Prep and water solution.  It is available at Lowes and contains Phosphoric Acid.  You can see how much is cleaned off half of it.
Second, more soaking followed by wire brush scrubbing and more soaking.  Repeated a bunch of times, plus sanded with coarse sandpaper and soaked some more...
« Last Edit: March 27, 2011, 05:39:03 PM by kpier883 »
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline kpier883
  • is quite the
Re: Small Project - Repair and Paint Engine Guards
« Reply #1 on: March 27, 2011, 05:40:56 PM »
Next, one of them primed and ready to sand.  Then, after sanding.
This was repeated several times to fill all pits.
« Last Edit: March 27, 2011, 05:42:37 PM by kpier883 »
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline kpier883
  • is quite the
« Reply #2 on: March 27, 2011, 05:44:09 PM »
Fix All rattle can black has been applied to the first one!
I am hoping that these will provide a place to shift my feet to on longer rides.  I know the paint will scratch easily with boots on them, so I may look for some kind of rubber to wrap around where the boot would rest.
I am pleased with how the first one turned out and am looking forward to finishing up the second one.
Thanks again to forum member Mynameismudd (Derek) !
« Last Edit: March 27, 2011, 05:51:52 PM by kpier883 »
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline MasterChief750
  • Detonation
« Reply #3 on: March 27, 2011, 06:44:24 PM »
put some clampon highway pegs on them and ull have less scratches on em
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
