Author Topic: cb750 k1 kickstart repair  (Read 6674 times)
Offline plippo
  • A but crazy about Honda's
« on: March 28, 2011, 05:47:03 AM »
hi guys,
i just got a 750 k1 as a new project (not finished the K2 though...:-))
the bike was parked by the Po in 1982 with 13,000 miles and was running. The kick starter was not working so the PO always used the electrict starter. (the engine turns).
The kick has  a problem, it will go down freely, not engaging anything inside.
what could the problem be? anything I can repair without taking the engine off the frame?
thanks
fil
Cb750 K0, 1, 2, 6, F1
Cb500 K0, 1, 2
Cb550 K '78
Cb550 SS F0, F1, F2
Cb400 F1
Cb450 Blackbomber
Cb450 73
CL450 68
CL350 71
GL1000 K0,1,2,3,Z
Cb250 K0
CB125 K0
XL250 K0, K3
VF500
VFR750
Spacy250
they all look good form the distance!
Offline wrenchmuch
Re: cb750 k1 kickstart repair
« Reply #1 on: March 28, 2011, 06:03:03 AM »
Its likely the pawl or spring on the kick start mechanism . You need the engine out and the lower cases split to work on it .
CB750K1
CB750K4
Offline Johnie
« Reply #2 on: March 28, 2011, 06:35:10 AM »
Most people use the electric start anyway. If your electric starter works I would not mess with it. Heck, if the electric start goes out just give it a good push and pop the clutch to start it. I see to many people split cases, etc. and end up with more problems than they started with. Have fun with your new project.
« Last Edit: March 28, 2011, 06:37:36 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #3 on: March 28, 2011, 06:58:58 AM »
Could be a pawl or such. My experience has been with broken KS shafts. Usually with high compresion motors, using kick only starts. The shaft would shear in 2.
In either event, it is an engine tear down, though it can be done leaving the top end intact. Remove the engine. Remove the lower case side covers. Flip the engine upsude down. Remove the lower case. Fix the KS. Reverse the disassembly. COuld be done on a saturday.  Other than chasing parts.
Offline plippo
« Reply #4 on: March 28, 2011, 08:05:53 AM »
What would be the risk of keeping it as it is (assuming the engine does not need any other repair)? any risk of loose parts inside? anything I can check from the side engine covers?
thanks
fil
Cb500 K0, 1, 2
Cb550 K '78
Cb550 SS F0, F1, F2
Cb400 F1
Cb450 Blackbomber
Cb450 73
CL450 68
CL350 71
GL1000 K0,1,2,3,Z
Cb250 K0
CB125 K0
XL250 K0, K3
VF500
VFR750
Spacy250
« Reply #5 on: March 28, 2011, 08:08:42 AM »
thanks
fil
A broken shaft is no problem, everything stays right where it is, except the lever of course. Do you have it tied up somehow?
AS to pawls or other internal pieces coming loose, I've no experience with that. But my guess is at worst it would fall down to the sump pan and stay there.
Offline Johnie
« Reply #6 on: March 28, 2011, 08:12:44 AM »
You can just take that kick start off if it gets in the way until you decide to tear into it.
Oshkosh, WI  USA
« Reply #7 on: March 28, 2011, 09:31:54 AM »
Read this.
 A while back I picked up a 78 750F, tried to check compression, kicker was limp, I was pissed
 Then in Feb in a cold snap, I had a few days where the kicker on my daily rider froze and did not work.. I would bumpstart it. and then it would work again
 So I am thinking, if you strip out the clutch and cover, you MIGHT be able to get at the ratchet and pawl, and lube the snot out of it, or free it up.. IF.....IF the spring and pawl are still in there. But I am not sure it can be reached or done, but it is worth looking at.
 If anyone has a engine with cluch basket out, maybe they can take a look for us?
Offline Johnie
« Reply #8 on: March 28, 2011, 12:48:58 PM »
This is a K4, but you will get the idea. 1st pic with the clutch basket out. 2nd pic of the kick lever spring. If you need more pics let me know. Click the pic to enlarge it...
Oshkosh, WI  USA
Offline plippo
« Reply #9 on: March 28, 2011, 02:44:37 PM »
thanks - clear
it seems then that to access the spindle(?) you need to dismantle form the top end then...?
Cb500 K0, 1, 2
Cb550 K '78
Cb550 SS F0, F1, F2
Cb400 F1
Cb450 Blackbomber
Cb450 73
CL450 68
CL350 71
GL1000 K0,1,2,3,Z
Cb250 K0
CB125 K0
XL250 K0, K3
VF500
VFR750
Spacy250
« Reply #10 on: March 28, 2011, 02:49:39 PM »
thanks - clear
No, you can get to it the way I described. Flip it over and take the bottom off. The first pic is right side up. The second pic is upside down, the spindle is assembled into the top case.
« Last Edit: March 28, 2011, 02:51:31 PM by MCRider »
