Author Topic: Vac Sunc issues  (Read 1229 times)
Offline Duanob
  • Bold Timer
  • Gotcha!
Vac Sunc issues
« on: March 29, 2011, 08:47:24 AM »
1976 CB550K 022A carbs.
I installed the typical 4 gauge vac sync tool and made sure there were no vac leaks and everything was tight and well connected. I couldn't get the bike to run right. It made it hard to read the gauges. At idle the gauge needles fluctuate wildy. At 3000 rpms I could get the needles to settle down in a certain location on the gauge but the engine would fluctuate wildy and spit and sputter. It was also running super hot. I burned my arm by accidently touching it it was so hot. Also I noticed when I changed one carb the other carb would self adjust making it hard to adjust two carbs at the same place on the gauge. After fighting with it, I got all 4 carbs kind of close. When I took the tool off the bike ran great. Do I have a defective tool? Anybody else have these kind of issues when trying to do a sync? BTW The 3000 mile tune up was done before the sync.
When a motor runs hot is it running too lean? Too rich? The timing is set pretty close to 1 - 4 and 2 - 3.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Re: Vac Sunc issues
« Reply #1 on: March 29, 2011, 09:22:57 AM »
Doesn't your gauge set have damper valves to limit needle excursion?
Didn't you have a fan blowing on the motor for the extended idle period?
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
Re: Vac Sunc issues
« Reply #2 on: March 29, 2011, 08:38:05 PM »
Quick question: if the temp is down in the 40s, will I still need a fan while sync'ing the carbs?  Might be tough to get a fan out to the curb....
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Re: Vac Sunc issues
« Reply #3 on: March 29, 2011, 10:43:32 PM »
Not if you are fast.  You should still be able to put hand to valve cover.  And if it's 40, you might even enjoy that!  ;D
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
Re: Vac Sunc issues
« Reply #4 on: March 30, 2011, 05:24:42 AM »
Thanks TT.  I am not sure how "fast" I will be, but the temps have been OK for curbside wrenching this past week, since the sun shines on my side of the block for the better part of the afternoon.
This winter, as long as the sun has been shining, I have been good out there, with temps down into the low 30's.  But man, I can't wait for the Spring to finally kick in!
~Sophocles
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: Vac Sunc issues
« Reply #5 on: March 30, 2011, 12:59:42 PM »
Q1) I don't know, tell me more.
and
Q2) no. it was forties when I synced my carbs as well but the engine definitely ran hotter than normal while the guages were attached. After I pulled the gauges and started her up and let her idle, heat wasn't much of issue then.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Re: Vac Sunc issues
« Reply #6 on: March 30, 2011, 01:20:50 PM »
The gauge set usually comes with an inline valve (thumb/finger operated) which restricts the air flow between gauge and manifold tap point.
These are tweaked to limit the needle excursion extremes so that a reading during strong idle pulses can be damped out.  If you don't have those, check an aquarium supply for air line valves.
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: Vac Sunc issues
« Reply #7 on: March 30, 2011, 01:23:48 PM »
Thanks TT, I know my set doesn't have any valves inline for sure.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
Re: Vac Sunc issues
« Reply #8 on: March 30, 2011, 01:42:19 PM »
My emgo system came with them. Little white pieces that have the knob to clamp down. Definitely needed on my sync, before that damping, they were bouncing all over the place.
~Sophocles
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: Vac Sunc issues
« Reply #9 on: March 30, 2011, 01:48:21 PM »
**slap forhead/shrug shoulders** So that's what those little white plastic pieces are for. **kick self in arse**
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Re: Vac Sunc issues
« Reply #10 on: March 30, 2011, 01:49:34 PM »
LOL
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
Re: Vac Sunc issues
« Reply #11 on: March 30, 2011, 02:02:54 PM »
Fixing SOHCs one small, seemingly insignificant knob at a time :)
~Sophocles
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: Vac Sunc issues
« Reply #12 on: March 31, 2011, 12:49:30 PM »
LOL you should use that for you sig line, it's perfect!
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
