Author Topic: Am I crazy, o do new coil wires help?  (Read 430 times)
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« on: March 29, 2011, 06:11:07 PM »
I finally got around to splicing new coil wires onto my old ones, using NGK splicers. I got new wires, and had already gotten new plug caps a while back.
Ok, I know this might be placebo effect. The bike was running pretty well before. But my first ride, and more importantly, my second (because I wasn't as focused on the new fixes) seemed to have a little more pep. A little more solid power through the sweep of the throttle.
I only went on a short ride locally, so lots of starts and stops (city riding), but it felt pretty good. Maybe just residual pride in having not completely screwed it up? :)
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline Mainerider
  • '04 VFR 800, '96 VFR750, 2001 SV650
Re: Am I crazy, o do new coil wires help?
« Reply #1 on: March 29, 2011, 06:50:07 PM »
Absolutely, it could be marginally better.  If your old wires were operating at significantly higher than spec resistance, you could have had a less than ideal secondary ignition spark going to the cylinders; your bike may have more complete fuel combustion now and you are feeling it in the seat of your pants, so to speak.  Good job.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #2 on: March 29, 2011, 06:57:22 PM »
That's sorta what I was thinking.  It seemed more responsive, and I hoped that the improved juice would be productive.
Now for a Spring carb sync, the improved air recirculation i will have ina week, and I should have this thing in good running order for the World Tour Relay.
Thanks!
~Sophocles
