Author Topic: UK Newby - '76 CB550F - First bike, first project!!  (Read 1263 times)
Offline xander
« on: March 30, 2011, 01:35:21 PM »
Hi all,
picked up this last week.  I am totally green when it comes to bikes and engine mechanics in general  Pretty adept at electrics and electronics and like a challenge so dove in head first!
Was running OK when I picked it up but after having the carbs drained to put it in my van and getting it back home it doesn't idle very well.  Cuts out when revs are low (>1000rpm).  Is it likely draining the carbs means the gunk and crap in there has blocked stuff up?  Would I be wise to give them a clean and have another go?  Any advice appreciated.  Just looking to get the bike running for now then think of mods later, want to keep it as a running project as best I can.  Based up in Manchester, UK if anyone else is local?
Got a Honda manual for a 74 and 77, are these still going to be useful, any major changes to be aware of between years?  Also ordered a Haynes manual.
A
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: UK Newby - '76 CB550F - First bike, first project!!
« Reply #1 on: March 31, 2011, 04:46:38 AM »
Hi "A"
A full carb strip and clean is probably the least you will get away with!
Two things to do immediately:
1. Put your location in your Profile so that we can all see it
2. Check out www.sohc.co.uk - the UK Chapter! Same s/w (older version). Use the same name so that we recognise you. We have a thriving community in the NW so there's bound to be someone close.
Steve
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
