Author Topic: Need rear brake pedal spindle placement help.  (Read 498 times)
Offline timdhawk
  • 1978 CB750K
« on: March 31, 2011, 02:28:08 PM »
How is this assembly supposed to go so that the spindle arm that connects to the brake rod isn't resting against the swing arm from the spring tension?
Under normal factory conditions, would the actual brake pedal rest against the stock foot peg tokeep it off the swingarm?
In deeper than I should be...
bollingball
Re: Need rear brake pedal spindle placement help.
« Reply #1 on: March 31, 2011, 02:45:34 PM »
There is a adj. bolt & nut mounted to the stock foot rest bracket when brake pedal is lined up on spline then you adj. and it will not be on swingarm. That is if it is a 750 K8.
