Author Topic: Need help/answers about CB550F Carb Linkage  (Read 836 times)
Offline ttarmijo
« on: April 01, 2011, 07:14:11 AM »
Yes, a green newbie.
I don't understand how to properly disassemble this linkage. I've removed carbs 1 and 2  from the Plate Set Stay, but don't understand how to remove carbs 3 and 4.  Which area do I disassemble (red arrows in pic ?).  Does the shaft (blue arrow) press out? Do the screws holding things on the shaft thread into the shaft, or just press against the shaft? I tried to loosen one of the bolts (green arrow in pic) and the bolt snapped off - I can repair with a drill and easy-out once I get things apart but don't want to damage anything else - advice from some EXPERTS !!!!!!!!
Offline fletcha221
  • CENDSE BIKEWORKS
  • Cendse Bikeworks
    • OUR SHOP
Re: Need help/answers about CB550F Carb Linkage
« Reply #1 on: April 01, 2011, 07:22:32 AM »
Hey, You don't need to touch anything on the main Assembly, You need to unscrew the 2 caps located by the Large red arrow. Remove the spring and pin. Then push the arm down and it will come out of the carb adjustment assembly. Leave everything else intact.
"Consistency is the last refuge of the unimaginative" -Oscar Wilde
1973 CB350f
1975 CB550k
1975 CB750 K5
Offline ttarmijo
« Reply #2 on: April 01, 2011, 07:29:44 AM »
Fletcha, I think you saved me from creating some BIG problems for myself.  I owe you one.
Offline fletcha221
  • CENDSE BIKEWORKS
  • Cendse Bikeworks
    • OUR SHOP
« Reply #3 on: April 01, 2011, 07:38:37 AM »
Hey man, You should download a shop manual off the site here, it will walk you through the whole rebuild.
1973 CB350f
1975 CB550k
1975 CB750 K5
