Author Topic: Ground to motor and frame or just frame?  (Read 769 times)
Offline timdhawk
  • 1978 CB750K
« on: April 04, 2011, 04:52:26 PM »
Can I ground just to the frame somwhere other than stock or does the main ground have to be on an engine hanger bolt? Does the motor need a specific grounding point or (if it needs one) will it ground through the hanger bolts?
Thanks
In deeper than I should be...
Offline scunny
  • don't call me expert
Re: Ground to motor and frame or just frame?
« Reply #1 on: April 04, 2011, 04:54:31 PM »
the motor will ground thru it's mounting bolts if the surfaces are cleaned back to metal
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #2 on: April 04, 2011, 04:59:06 PM »
Scunny is right, but since there are electrical devices on both motor and frame,
they both need to be attached to a ground source.
Bikes parked out front mean good chicken-fried steak inside.
Offline timdhawk
  • 1978 CB750K
« Reply #3 on: April 04, 2011, 05:43:16 PM »
Cool. thanks guys! I kinda thought that was the case. My frame is powder coated and I want to be sure where my ground NEEDS to be before I start any sanding.
Offline GammaFlat
« Reply #4 on: April 04, 2011, 06:08:21 PM »
I think it makes sense to do it like the factory did.  The largest load your bike will experience is the starter.  That's why the big ground cable from your battery goes to the engine mount bolt (the starter is grounded in the engine).  The small green wire near the seat latch is important as well.  Bikes mis-behave when the little green one gets a corroded/compromised connection to the frame.
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
