Author Topic: Battery life question  (Read 552 times)
Offline sky56
  • would you like to see my
  • Chgo winters can suck but great time to wrench
« on: April 04, 2011, 05:40:00 PM »
Hey everyone my friend recently acquired a cb400 and the battery that's in it is about a season or 2 old. The bike hasn't been started in about the same time frame if I guessed. The battery reads about 9v on my multi meter and he asked me if he fills it up with acid (I have lots of extra battery acid around the garage) and puts it on a trickle charge will it work? I know a new battery isn't very expensive but he's got alot going on at the moment and saving a few bucks at the current time will help him greatly. So will it work? I had no idea which is why I'm posting this. Thanks everyone
Ps he's not planning on any long distance riding but if he can join my friends and I for some city type riding that's what he'll do for the moment once the bike is up and running
Many honda bikes and a lifted 75 Chevy K5
Re: Battery life question
« Reply #1 on: April 04, 2011, 05:47:16 PM »
No.  Fill it with distilled water and try to charge it.  It might recover but, it is probably sulfated.  More battery acid will make the acid strength too strong and accelerate internal corrosion.  Once the cell interlinks are corroded away, it's only good for recycling.
For city riding, he's going to need a strong battery, as the charging system doesn't put out good power until the engine is revving above 3000 RPM.  Below about 2000 RPM the battery is draining, if the lights are on.
Offline Kong
« Reply #2 on: April 05, 2011, 04:57:01 AM »
Trash it - the thing is no good.  The very best way to utterly kill a battery is to just let it discharge and then let it set.  From your description that is exactly what someone did to this one.
To answer your question though, a battery that gets any sort of decent treatment will last 3 years and if you don't over heat it, keep it charged and full of electrolyte, and don't store the bike with it partially discharged it should last five years or more.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
bollingball
« Reply #3 on: April 05, 2011, 09:24:55 AM »
Sky you and your friend should read this.
http://www.google.com/search?q=battertstuf&sourceid=ie7&rls=com.microsoft:en-us:IE-SearchBox&ie=&oe=
