Author Topic: protective finish for bare metal engine?  (Read 1642 times)
Offline c(b)hris
« on: April 05, 2011, 09:10:11 AM »
The paint on my engine is peeling pretty badly.  If I sand the old paint off, do I have to do something to protect the bare metal?  I kind of like the way it looks like this.
thx
75 CB550
74 CB750
Offline c(b)hris
Re: protective finish for bare metal engine?
« Reply #1 on: April 05, 2011, 11:27:37 AM »
Does everybody just paint?  I found lots of threads on that.
This looks like what I want to do: http://forums.sohc4.net/index.php?topic=63092.150
About halfway down the page.
Can't find anything about a topcoat though.  Is it necessary to protect the metal?
Thanks in advance.
75 CB550
74 CB750
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: April 05, 2011, 11:31:35 AM »
Aluminum will oxidize if not protected.  Aluminum colored paint, like from the factory, helps to keep the look while keeping oxidation at bay.  You could clear-coat, but may have a hard time finding one that won't quickly turn yellow from the heat.
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« Reply #3 on: April 05, 2011, 11:44:27 AM »
I am planning on trying the same thing.  I was just part of a thread about this (search is a little flaky right now).
Often, people are using WD-40 to wipe down the tank, which will apparently protect it for a time.  Im thinking about trying Penetrol to accomplish the same thing.
It seems the clear coats are not typically good enough to handle gas/sun without discoloring.
Let me know what you come up with.
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline c(b)hris
« Reply #4 on: April 05, 2011, 11:54:15 AM »
Anyone know what are the chances of WD-40 on the engine case causing a fire when the engine gets hot?  Would the flammable parts dissipate during the application maybe?
75 CB550
74 CB750
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #5 on: April 05, 2011, 11:58:16 AM »
Sorry, I thought you were talking about the tank.
The engine is a different matter.  But if some WD-40 on the engine caused explosions, I'd be wrenching a CB on a cloud right now :)
I've dripped my fair share on there....
Don't know if I would rub a coat on there though.
~Sophocles
Offline camelman
  • Man... Myth... Legend
« Reply #6 on: April 05, 2011, 12:56:53 PM »
I use WD-40 when I scrub my chrome exhaust.  I wipe it down afterwards and let it the remaining oil burn off when I start the engine.  I don't leave much on there, but I doubt there'd be a problem if I did.  It would just evaporate or smoke a little bit more.
Regarding engine paint, some people swear by the dupli-color engine enamel and others have had some troubles with it chipping.  I haven't had any trouble with it, and have seen no fading after over a year of use and sunshine.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline Ricky_Racer
« Reply #7 on: April 05, 2011, 11:01:47 PM »
Gibbs.  8)  RR
« Reply #8 on: April 06, 2011, 12:34:15 AM »
If the metal were pure aluminum, it would create and oxide coating (clear) and that would be a barrier for future use.
However, the metal is an alloy and has other metals blended with it.  It will corrode and become nasty with time and exposure to the elements.
WD-40 will leave and nice oil coating, which is pretty good for attracting and holding onto dirt.   Paint it with aluminum pigment paint if you like the aluminum color.
Leave it bare if you like to clean and polish it over and over.  If you must have clear, get the two part paint that needs catalyst to cure.
Offline HawaiiMike
    • Hawaii realtor
« Reply #9 on: April 06, 2011, 12:46:17 AM »
I'm going to try this on one of my hubs.  http://www.kbs-coatings.com/diamondfinish-clearcoat.html
It's easier and less expensive than powder coating.  According to the website it will work on engine blocks and heads too.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #10 on: April 06, 2011, 04:38:22 AM »
I'd be curious to see what you think.
~Sophocles
bollingball
« Reply #11 on: April 06, 2011, 05:00:47 AM »
What about the 325 degrees? How hot do our engines get?
