Author Topic: Brake caliper - piston stuck  (Read 18282 times)
Offline Dimitri13
  • 1974 CB550K
Re: Brake caliper - piston stuck
« Reply #25 on: December 18, 2011, 12:48:08 AM »
I had to get my piston out today. I didn't have access to a grease gun or air compressor and I had already taken the caliper off the bike.
What I did have though, was a bicycle pump and a fitting to stick into the brake line threads. A couple of pumps later, the piston popped out.
« Reply #26 on: February 09, 2012, 07:12:55 AM »
I baked the caliper - in alum foil - @500 for half an hour and it came right out. But only b/c I was lazy to set up the grease gun.
Offline grcamna2
« Reply #27 on: February 09, 2012, 07:18:54 AM »
70CB750,
     How did the piston look ?
« Reply #28 on: February 09, 2012, 10:30:17 AM »
Looking good, polished right up.
Offline AbbyRider
« Reply #29 on: March 09, 2012, 08:16:01 PM »
Wow. Just used the compressed air method. Thought it was going so smooth because the piston was creeping out ever so slowly. Then BANG! Man that thing shot out of there like a small missile. My shop heater took the brunt of it, but I sure am glad I wasn't staring at it watching the exit progress.
'98 VTR1000 Superhawk
'78 CB750F
'77 CB750F (in the works)
'81 KZ650 sitting in pieces in my basement
bollingball
« Reply #30 on: March 10, 2012, 09:21:34 AM »
Didn't you read about wrapping it in a towel ??? and being safe.
Ken
« Reply #31 on: March 10, 2012, 10:40:23 AM »
I done another with the grease gun and thats the best way.  Easy and safe.
Offline AbbyRider
« Reply #32 on: March 13, 2012, 09:42:00 AM »
Ken
[/quote]
Yeah - I did have it in a towel, but couldn't see if I was making any progress. Wasn't sure if it was actually going to work. So I took the towel off to see how it was doing, and then SURPRISE! Will be way more careful next time.
'78 CB750F
Offline Jay D.
« Reply #33 on: April 13, 2012, 09:18:58 PM »
+1 for the compressed air method - had great success tonight thanks once again to the forum.
Offline CapeCafe
« Reply #34 on: July 20, 2012, 05:16:48 AM »
I've been reading through this thread and need to remove a stuck piston from my brake caliber and the tools I have handy lead me to the grease gun method.  My questions is where to pump the grease.  One answer in this thread says to screw a 10mm grease nipple into the bleed screw.  It seems to make more sense to simply screw a grease nipple into the hole for the brake line and pump away like you would if the mstr cyl was pushing.  Which hole is best ?  I know thats a loaded question :)
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
1995 Ducati 900 SS/SP
2000 Ducati 900i.e.
« Reply #35 on: July 20, 2012, 05:44:25 AM »
Doesn't matter which hole. Leave the bleeder in, use the other. Remove the fitting from the hose leaving a stubby male thread. Its not the same thread as the hole, but it will catch a thread or two. That's all you need. Grease gun is several thou PSI. Piston will move slowly with each pump, safely. No "pop" and shoot across the room.
« Reply #36 on: July 20, 2012, 05:55:52 AM »
Either way works. I use the bleeder as nipple for grease gun - but you can move it to line hole and block the bleeder hole. Thread is the same.
« Reply #37 on: July 20, 2012, 06:00:14 AM »
The thread is the same - I moved my brake lines to the back and bleeders to the front for the dual disc setup. The only difference is the pressed in seat under the bleeder.
