Where abouts is the leak? Did you replace the shifter seal? Last but not least, I had the same issue and it turned out the oil leak was coming down from between the tranny and the stator cover. Sure looked like the tranny gasket. After I got into it I found it was the rubber seal from the stator wires needed some sealer. That took care of it.
