Author Topic: Swingarm Bushing (Sleeve?) Removal  (Read 14812 times)
Offline Sledgehammer
« on: April 06, 2011, 10:26:49 AM »
I just wanted to add that the Hacksaw is a good way to take these steel sleeves out of your swingarm however I also want to add my two cents.
Make sure there is plenty of tension on that hacksaw blade and be sure to cut in a straight line, some of my cuts were straight but a lot were not (shaking head).
And its best to make your two cuts, it should only take two, about 40 to 50 degrees to give enough so those sleeves just fall out. I made my first two cuts too close together and I was micron away from starting to cut into the swingarm I thought I could just tap it out with a flathead screwdriver and all it did was just break a little piece off. That is pretty much why I had to do more cuts, hence all those little sleeve pieces in the photo.
Also, I thought since the cuts werent exactly falling out I thought I would fit a socket in the pivot shaft and give it a couple of whacks, hoping those cuts would break, but they didnt and I think I ended up doing more damage than good and that is the second picture. I think I may have wedged the metal inside the pivot shaft.  :-\
Offline gnarlycharlie4u
  • Far from being an
Re: Swingarm Bushing (Sleeve?) Removal
« Reply #1 on: May 05, 2011, 10:32:34 AM »
oh my. thanks for the heads up that looks like a mighty mess.
I may just try and press them out. I'm just not sure how to go about doing it. I have a blind bearing puller and a 20 ton shop press but... yea I think I need to develop a strategy first.
Offline ksmith0034
  • When I grow up I want to be a
    • Please subscribe to my motovlog
« Reply #2 on: June 29, 2011, 06:35:05 PM »
Here is a nifty tool a machinist buddy of mine made to get mine out.  It's basically 4 pieces plus a driver.  Pretty slick!
It took 10 years but she's finally done!
Stocker 2 Rocker CAFE conversion
My YouTube channel HERE:
https://www.youtube.com/MotoCafeRacer
« Reply #3 on: November 16, 2011, 03:21:04 AM »
The tool is split in quarters?  Why?
Offline ksmith0034
« Reply #4 on: November 16, 2011, 11:11:27 AM »
So the pieces will fit through the bushing (assuming both sides are stuck).  Then the 4 pieces are reassembled inside the swingarm and driven against the inside of the stuck bushing with the long driver piece and a hammer.
« Reply #5 on: November 16, 2011, 11:36:03 AM »
Of course!   Smart tool, thanks!
Offline alacrity
  • Ride, Optimize, Repeat
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
« Reply #7 on: March 25, 2012, 05:10:47 AM »
Thanks.  Filed away for future use.
Offline Cvalero
  • CB550 owner, hackanic on the side
« Reply #8 on: April 24, 2012, 03:28:31 PM »
Ksmith0034, do you by any chance have a technical drawing of the tool that I could use to have one made?
1974 CB550 (project)
1977 CB550
Offline ksmith0034
« Reply #9 on: April 24, 2012, 06:41:12 PM »
Nope.  I doubt he made any drawings.  He told me he used some scraps pieces and made a tool that fit.
« Reply #10 on: April 25, 2012, 12:03:41 AM »
CB650 removed mine pretty easily by a little tapping. Came out as good as new. I think he carefully used a longer socket extension? I'll get him to chime in. Installing the new replacement bronze bushing was pretty easy too once they were removed from the freezer.
Offline cb650
« Reply #11 on: April 25, 2012, 12:44:10 AM »
Condition of the bike/bushings make a big difference.
Offline Cvalero
« Reply #12 on: April 25, 2012, 11:23:22 AM »
I think my bushings have achieved oneness with the swingarm tube.  Unfortunately I pulled the trigger on OEM bushings before reading all about bronze bushings.  One question:  The pictures of the aftermarket brass bushings I have seen appear to have a lip on them.  Would these bushings replace all three parts: pivot bushings, pivot thrust bushings, and the felt ring?  Perhaps the picture was just an example and not the actual part.
1977 CB550
Offline alacrity
« Reply #13 on: April 10, 2020, 12:07:49 PM »
yes.  It takes up space.  You might have room for the felt discs... you might not.
