Author Topic: Which modern master cylinder?  (Read 6424 times)
Offline lassenc
« on: April 11, 2006, 02:03:05 AM »
Hi!
I've seen another topic on the benefits of having a modern master cylinder, and looked through eBay.
I came up with a cheap Honda cylinder.
http://cgi.ebay.co.uk/Honda-CBR-600-sport-master-cylinder-lever_W0QQitemZ8047178274QQcategoryZ10460QQrdZ1QQcmdZViewItem#ebayphotohosting
Assuming it's 7/8 and fits on the handlebar, what other problems would you guess I could encounter?
I assume the banjofitting is a standardsize?
How exactly do you teach abstinence though?
It's like beating a dead cow, it's fun, but it doens't really get you anywhere.
Offline chrometank
  • cb750 1976 owned 33 yrs
Re: Which modern master cylinder?
« Reply #1 on: April 11, 2006, 02:16:47 AM »
Hey Lassenc, I installed a CBR250RR master cylinder that looks identical to that one on ebay,What a difference !  Mine was better than I thought it would be.
cheers
Offline Raul CB750K1
« Reply #2 on: April 11, 2006, 02:20:34 AM »
Do you mean that installing a modern master cylinder on an old CB750 will increase the stopping power? Without replacing calipers or pads? If that's what you mean I want one!!!
Raul
Offline chrometank
« Reply #3 on: April 11, 2006, 02:25:24 AM »
Hey raul,Thats exactly what happened with mine! I also have ss braided lines but they were on there with the old master which was just plain spongy.The new mc is only about 8 yrs old so ild say thats the difference.
cheers
Offline lassenc
« Reply #4 on: April 11, 2006, 02:27:17 AM »
I'm changing the pads as well, that's why I wanted to change the master cylinder now as well, only need to bleed the system once then :)
I've found more interesting auctions by the way, there are ALOT cheap, good master cylinders on eBay!
Offline cben750f0
« Reply #5 on: April 11, 2006, 02:52:24 AM »
yep the change to a newer master cyl makes heaps of difference, could beleive the change it made to the F1..peace
don76
« Reply #6 on: April 11, 2006, 04:06:56 AM »
I actually used a m/c off a Buell with a braided line and I think it works great even with the original calipers and pads.
Don
Offline lassenc
« Reply #7 on: April 11, 2006, 04:21:53 AM »
So I guess I just should take the cheapest one thats coming up :)
« Reply #8 on: April 11, 2006, 04:24:07 AM »
I have a spare suzuki M/C I bought for my GZ250, so I think I will give it a try when the time comes for the brake fluid change. That M/C have an integrated brake light switch, so I will probably get rid of the CB750 switch assembly and run a full hose from the cylinder to the caliper.
Raul
« Reply #9 on: April 11, 2006, 04:45:17 AM »
 Whatever you get I'd recommend it have a 5/8" bore.
Offline lassenc
« Reply #10 on: April 11, 2006, 04:56:03 AM »
Any special reason?
Offline Chris Liston
« Reply #11 on: April 11, 2006, 05:20:03 AM »
The new to me master that I have has a 5/8" piston in it.  Its from a 93 Ninja ZX7R.  That and the stainless lines I had already have made that little Honda caliper a stopping machine.  Stopping power and lever feel has increased 100%.  I don't feel any brake fade like I used to.  But I have to relearn how to brake on this bike because it stops now.  :)
Here's an Ebay list of front masters going on now.  I'd recommend something with a remote resovior so you can use clubmans or something and it will stay level.
http://motors.search.ebay.com/front-master-cylinder_Brakes-Suspension_W0QQcatrefZC12QQfromZR40QQfsooZ1QQfsopZ1QQsacatZ35592QQsamcmZ6028
« Last Edit: April 11, 2006, 05:26:08 AM by Chris Liston »
1976 CB550F Cafe in progress
Offline dusterdude
« Reply #12 on: April 11, 2006, 05:21:01 AM »
yea,single disc setups need a smaller bore than a dual disc.the larger bore is required on a dual disc so the mc can push more fluid for both calipers.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline lassenc
« Reply #13 on: April 11, 2006, 06:14:03 AM »
I know that, but I was just asking why it had to be THAT size :)
« Reply #14 on: April 11, 2006, 06:33:08 AM »
How do you know the piston size?
« Reply #15 on: April 11, 2006, 06:43:11 AM »
Most modern masters come with either 14mm or 5/8".   5/8" being the larger.  It will just put more pressure on the fluid.  My master actually says 5/8" on it.
Offline lassenc
« Reply #16 on: April 11, 2006, 06:44:57 AM »
Okay, it's great for my purpose then :)
If I want a dual disc later on, where can I get the speedo plate thingie I need?
Offline pwright
    • My SOHC Gallery Page >>
« Reply #17 on: April 11, 2006, 06:58:26 AM »
Very timely thread. I too plan to go with a modern master soon... is the banjo bolt a universal size amongst brake systems? Also, I have seen some master cylinders that have two hoses running off them, presumable a hose for each side of the dual discs... are most of them single line masters?
Later,
-Pat-
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #18 on: April 11, 2006, 07:02:18 AM »
Most Banjo's are 10x1.25, or around their...
I have not seen a master with dual outlets, but I would guess that would be for one (1) line per caliper. Most ones I see have a single line running from the master to some sort of splitter-Y Block, then a single line to each caliper.
As soon as I get my frontend back from Dragman, I get to do the brakeline thing myself.
Should be a blast  ::) ;D
Offline lassenc
« Reply #19 on: April 11, 2006, 07:11:34 AM »
I want to do the split line too.
What have you done on the speedoplate issue?
Offline tsflstb
« Reply #20 on: April 11, 2006, 07:19:01 AM »
You can use a dual banjo bolt and have 2 lines going directly from your master cylinder to each caliper.  This seems to be how the aftermarket braided lines are set up.  The 900RR m/c I use came this way.  I replaced it with a single bolt since I'm just running one disk.
Offline dusterdude
« Reply #21 on: April 11, 2006, 07:22:50 AM »
i gotta quit reading this thread,you guys are gonna make me go buy a late model mc for my gw frontend.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
« Reply #22 on: April 11, 2006, 09:00:15 AM »
I did exactly the same thing.  I kept that double banjo for future upgrade.  But I'll probably just put 2 lines off the stock junction.  Who knows :)
brockj
« Reply #23 on: April 11, 2006, 12:38:49 PM »
So I saw a few, but what modern master cylinders have people been using with success?  I am in the market for a new one, and if I am going to get one, might as well get a modern one.  Perhaps a new thread is in order for this, but what modern master cylinders have people succesfully used?
Offline cben750f0
« Reply #24 on: April 11, 2006, 01:26:12 PM »
i am using a vtr1000 m/c... only b/c its the one i had laying around... apparently the cylinder off and SP2(RC51) are a little larger... but it does the job well..peace
