Author Topic: Removing/Replacing Rebound Check Valve in fork tube?  (Read 557 times)
Offline stueveone
« on: April 08, 2011, 08:45:46 PM »
Anybody know if you can remove and replace the check valve in the bottom of CB750 fork tubes? Circa k7. Is the top collar above the middle floating washer pressed in or something? I've heard Forks by Frank uses circlips. But, unfortunately, I have tubes from cycleX. Hmm. . .
