Author Topic: Picking up a 76LTD Wing (With Pics) Now Owner  (Read 3984 times)
Offline 78 k550
Re: Picking up a 76LTD Wing (With Pics) Now Owner
« Reply #25 on: April 25, 2011, 08:06:55 PM »
Clutch is slipping very bad.
Paul
Your description of how much pressure was on the clutch lifter screw pretty much says it all. It was screwed in so far that it held the clutch partially disengaged. Expect to find friction plates worn to the bone. When you replace the plates, pay attention to which direction the spiral groove faces. The shop manual has a good line drawing to explain it. The one plate with the different sized tabs is the last one into the basket.
Stu
Thats for fluid flow correct.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #26 on: April 25, 2011, 10:54:47 PM »
I'll be on the 75.
Paul
Why am I not surprised  ;)   ;D
