Author Topic: 74 CB750 kickstart won't recoil  (Read 1467 times)
Offline rt1976
« on: April 09, 2011, 09:03:39 AM »
Hello all,
Just like the topic says. I rebuilt this engine and it runs fine, but the kick starter will not return to upright. It will turn the engine over but I have to bring the lever back up by hand. I must have not locked the spring into position. My question is can I get to it by dropping the oil pan and oil pump, or do I need to split the cases to access the spring? Based on my rebuild pics it is on the shaft. Maybe it bound up and broke when I first kicked it over?
Thanks...
Re: 74 CB750 kickstart won't recoil
« Reply #1 on: April 09, 2011, 09:10:59 AM »
Hello all,
Thanks...
It will require pulling the engine, flip it over and remove the lower case. When you install the kicker, the spring needs to be "wound up" a bit and you likely skipped that step. easy to do.
Offline rt1976
« Reply #2 on: April 09, 2011, 11:37:52 AM »
That's what I was afraid of....I love learning the hard way...
Thanks
« Reply #3 on: April 09, 2011, 11:42:26 AM »
Thanks
I did mine recently that's how i know. had to ask the forum for help. There's a trick to it, but not hard.
