Author Topic: Brake calipers / arms ID help  (Read 588 times)
Offline cobra2411
« on: April 09, 2011, 09:43:53 AM »
I thought I had collected 2 of the same calipers/arms for my dual disc conversion but I realized they are different...
One is a 750 arm and caliper with an approximate 42mm piston. The other has a 38mm piston and the mounting holes are located closer together. CB550?
Here are some pics
Offline stueveone
Re: Brake calipers / arms ID help
« Reply #1 on: April 09, 2011, 10:36:49 AM »
Does one of the have fins and the other doesn't? Honda switched the caliper in 76-77 to a larger piston diameter. It is the better design in my opinion and if that's the one you have, I would find a match.
Offline cobra2411
« Reply #2 on: April 09, 2011, 10:47:42 AM »
No, they look the same, just one is bigger. I have a finned one on the bike now (K1 front end.)
« Reply #3 on: April 09, 2011, 11:03:03 AM »
The caliper with the 42.7 mm piston is from a K7-K8 750. The 38 mm caliper with the narrow bolt holes is from a smaller bike. The K1 finned caliper has a shorter arm than later versions, and also mounts at a different angle. In other words, neither of those will work on a K1 front. You need an early caliper with a matching arm.
Offline cobra2411
« Reply #4 on: April 09, 2011, 04:12:21 PM »
I have K7 forks that I want to run in my K1 clamps. I'm collecting parts for a dual disk swap. I have 1 K7 bracket & caliper; thought I had 2... Just wanted to confirm the smaller caliper & bracket was off a small bike.
