Author Topic: 72 Honda cb350f tranny/sprocket question?  (Read 791 times)
Offline lhemrick
« on: April 10, 2011, 02:40:12 PM »
My son has a 72 350 four and I noticed today when I took her for a spin that it has some lag in the sprocket on the motor. I put the bike up on some blocks to clear the rear wheel and in gear you can rock the wheel back and forth between an 1/8 to 1/4 turn on the sprocket. Is this normal? Is something going wrong in the tranny or do I need to replace the sprocket?
Don't give up; Rust is only Temporary!
77 Honda CB750
70 Honda CB350 twin
71 Honda CB350 twin
72 Honda CB350 Four
72 Honda CB175
81 KZ550C2
81 KZ750H2
82 KZ750M1 CSR
84 ZN700 Shaft
Offline little honda
Re: 72 Honda cb350f tranny/sprocket question?
« Reply #1 on: April 10, 2011, 03:41:18 PM »
IS THE PLAY BETWEEN THE SPROCKET AND THE SPLINE ON THE OUT SIDE? OR DOES THE OUTPUT SHAFT ROCK BACK AND FORTH GOING INTO THE CASE? OR BOTH.
Offline lhemrick
« Reply #2 on: April 10, 2011, 05:31:20 PM »
I don't know right now I don't have the tools with me to check it. If its the shaft is that bad?
77 Honda CB750
70 Honda CB350 twin
71 Honda CB350 twin
72 Honda CB350 Four
72 Honda CB175
81 KZ550C2
81 KZ750H2
82 KZ750M1 CSR
84 ZN700 Shaft
« Reply #3 on: April 11, 2011, 01:09:15 PM »
IGUESS I WAS JUST WONDERING IF THE PLAY IS INSIDE THE GEAR BOX OR OUT SIDE. THERE IS USUALLY SOME PLAY IN THE GEARBOX SYSTEM. IF IT RIDES AND SHIFTS OKAY, I WOULD GO AHEAD AND RIDE, PAYING ATTENDSION TO A SMOOTH RIDE AND LISTEN FOR ODD CLANKING OR DESTRCTIVE NOISES.
Offline lhemrick
« Reply #4 on: April 11, 2011, 03:31:04 PM »
Thanks, I have about decided the same. It is the entire shaft rocking back and forth but not as much as I thought. It doesn't make any odd sounds or grinding its just when rolling and you throttle and let off and throttle again you can feel or tell that there is some play at the sprocket.
Thanks,
Lynn
77 Honda CB750
70 Honda CB350 twin
71 Honda CB350 twin
72 Honda CB350 Four
72 Honda CB175
81 KZ550C2
81 KZ750H2
82 KZ750M1 CSR
84 ZN700 Shaft
Offline camelman
  • Man... Myth... Legend
« Reply #5 on: April 11, 2011, 08:24:00 PM »
Is your chain loose?  If you are getting drivetrain slop, then it could easily come from a loosened chain.  They need to be adjusted every so often.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline lhemrick
« Reply #6 on: April 12, 2011, 05:12:33 AM »
Chain is tight, there just seems to be more play at the sprocket than I think there needs to be.
77 Honda CB750
70 Honda CB350 twin
71 Honda CB350 twin
72 Honda CB350 Four
72 Honda CB175
81 KZ550C2
81 KZ750H2
82 KZ750M1 CSR
84 ZN700 Shaft
bollingball
« Reply #7 on: April 12, 2011, 05:35:39 AM »
Chain may be tight but is it wore out ? tight in one spot loose in another?
