Author Topic: What is the purpose of this piece? Carb related  (Read 1225 times)
Offline jneuf
« on: April 10, 2011, 07:30:14 PM »
022a carbs off cb550. There is a little piece of flimsy metal in between the lock nuts and adjusting screws at the top of the carbs, in between carbs 1 & 2, and 3 & 4....the piece is in tact on my 1 & 2 carbs, but is broken between the 3 & 4 carbs...I've posted a picture to show what the part is....those aren't my carbs though.
What is the purpose of that piece of metal? How is it affecting my carbs if the piece between 3 & 4 is broken?
'75 CB400f
Offline apex_seeking
  • Ron Swanson is a
Re: What is the purpose of this piece? Carb related
« Reply #1 on: April 10, 2011, 08:15:39 PM »
As far as I know, it's just a holder plate to aid in keeping the carbs in line and in place.
Offline westondc
  • Wes Mantooth
« Reply #2 on: April 10, 2011, 08:52:00 PM »
It's been a while since I've gone through my CB500 carbs, but I'm thinking that plate helps to keep the carbs that are paired together in sync with each other. without that piece there is a little play in the linkage. so without it your carbs are not going to stay in sync and you will have power and idle issues. you could fabricate something to replace it or order a new one.
« Last Edit: April 10, 2011, 08:53:40 PM by westondc »
B.O.X.N.I.F.E. Hospital fund https://www.everribbon.com/ribbon/view/8352
Rider no. 115 on the 2012 SOHC/4 Honda World Tour
Rider no. 274 on the 2011 SOHC/4 Honda World Tour
1972 Honda CB500k1
1971 Honda CB350k3
the project http://forums.sohc4.net/index.php?topic=64499.0
Trip/Project Blog http://easterntowestern.blogspot.com/
just be a vagabond, living out of a backpack on a little Honda, cruisin all over the damn place....
"As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?"
Offline jneuf
« Reply #3 on: April 10, 2011, 09:02:49 PM »
Interesting...thanks. I may just fabricate something if that is the case. That piece seems really fragile. I haven't synced my carb yet, but It seems like that piece really twists if you attempt to loosen the lock nuts...?
'75 CB400f
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« Reply #4 on: April 10, 2011, 09:08:28 PM »
That piece definitely effected my carb sync.  While sync'ing I accidentally pushed down on the screw too hard, which flexed that piece.  And the reading on the the adjoining carb definitely moved when I did this.
Best to fab/replace it.
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline jneuf
« Reply #5 on: April 10, 2011, 09:13:42 PM »
Weird. I suppose I'll fab it with something a little more sturdy. I didn't even notice it was broken. Is there a trick to loosening up the locknut without putting stress on that piece?
'75 CB400f
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #6 on: April 10, 2011, 09:15:33 PM »
I was able to loosen it without any trouble.  Loosening should be moving away from the piece anyway, so even a new, thin piece of sheet metal should work.
~Sophocles
« Reply #7 on: April 10, 2011, 09:26:29 PM »
ive deleted them with no worries.
Offline jneuf
« Reply #8 on: April 10, 2011, 09:33:30 PM »
Hmmmm...good to know! I've gone through the full tuneup on my bike now and was going to sync the carbs tomorrow. I looked and saw that and got worried! I suppose I'll see how much it will affect the carbs during the sync!
'75 CB400f
« Reply #9 on: April 10, 2011, 09:49:20 PM »
I believe the piece is multi function.
1 - is to help keep the adjustment nuts from loosening up
2-  is to keep the ball links centered in the sockets, and their holders straight.  If they angle, the distance changes, which results in out of balance condition at some throttle positions.
Offline MoMo
  • Ride like you're invisible
« Reply #10 on: April 10, 2011, 09:53:26 PM »
Ditto on that, none of my bikes have the two pieces...Larry
Offline SanDogDewey
« Reply #11 on: April 10, 2011, 10:05:23 PM »
If you are going to replace it, it needs to be flexible enough to allow each carb to be adjusted independently.
Offline westondc
  • Wes Mantooth
« Reply #12 on: April 10, 2011, 10:59:51 PM »
the bike will run without it I'm sure. it might not be noticeable but it can effect the bikes performance. the part was put there for a reason, might as well spend a few minutes fabricating one IMO
1972 Honda CB500k1
1971 Honda CB350k3
