Author Topic: Carb Sync port stripped  (Read 2366 times)
Offline jimbojangles
« on: April 10, 2011, 08:14:15 PM »
Has this happened to anyone? the vacuum port on one of my carbs is apparently stripped. The screw just kept spinning when I went to reinstall. I don't think I overtightened because it just never got tight. I think there is one thread left at the very end because I finally got the screw to go in without the washer. However, now I don't know what I will do next time I have to sync. I don't want to permanently ruin the carburetor body.
I was waiting to ask how to fix this, but I may have stumbled on to a solution. Can anyone tell me what exactly this part on Z1 Enterprises is? It says it's a permanent mount vacuum gauge adapter. Is this something I could mount in the vacuum port so that I don't risk messing things up next time I have to sync? Any explanation on how it works would be great.
http://www.z1enterprises.com/detail.aspx?ID=4368
Thanks
1974 CB350F
2013 VFR1200F
Offline vrenlos
Re: Carb Sync port stripped
« Reply #1 on: April 10, 2011, 08:47:10 PM »
It looks like that would work fine, but doesn't that part have to thread on as well?
1975 CB550K1
2009 Ducati Monster 696
« Reply #2 on: April 10, 2011, 08:54:24 PM »
I have one thread left that I can probably screw it into. I figure that one thread and some liquid gasket should hold up fine.  I just don't want to push my luck any farther by using those threads any more than I have to.
I've searched around and feel stupid for having to ask this. How does this work? I mount it to the carburetor, I get that. But how do I connect my vacuum gauges later? I can't tell from the picture.
1974 CB350F
2013 VFR1200F
Offline westondc
  • Wes Mantooth
« Reply #3 on: April 10, 2011, 09:00:54 PM »
nice find, I'm going to get myself a set and give them a try. i always seem to have fits getting my sync tool pipes to thread into my carbs. only issue i see with this adapter is the difficulty you might have getting to it when you need to hookup the hoses.
B.O.X.N.I.F.E. Hospital fund https://www.everribbon.com/ribbon/view/8352
Rider no. 115 on the 2012 SOHC/4 Honda World Tour
Rider no. 274 on the 2011 SOHC/4 Honda World Tour
1972 Honda CB500k1
1971 Honda CB350k3
the project http://forums.sohc4.net/index.php?topic=64499.0
Trip/Project Blog http://easterntowestern.blogspot.com/
just be a vagabond, living out of a backpack on a little Honda, cruisin all over the damn place....
"As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?"
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: April 10, 2011, 11:00:12 PM »
It works the same as the temporary adapters you currently have, except these come with a rubber cap that seals the opening when you're not using them.
« Reply #5 on: April 11, 2011, 07:16:58 AM »
YEAH!...liquid gasket one of these in.  i got my set from Motion Pro a while back.  they work slick.  just leave them in and put the little rubber hat over when not in use...slide them off and put on your carb gauge tubes and you're synching.... 8)  no more burnt knuckles or dropped screws
« Reply #6 on: April 11, 2011, 08:06:17 AM »
Ok, I think I got it. Correct me if I'm wrong.
Screw this thing into the carb. Take the brass tubes off of my sync gauges and instead the rubber tube from the guages just slides over the spigot on the adapter? Put the rubber cap on it when not in use? If it makes a difference, I have the cheap dial gauges with the brass fittings.
It would make my day and probably save me hours if this means I don't have to search for the #3 carb screw that I drop down between the carbs every single time I try to reinstall.
1974 CB350F
2013 VFR1200F
« Reply #7 on: April 11, 2011, 08:14:36 AM »
yeah...thats it.
(4) cost me about $20.
http://www.motionpro.com/motorcycle/partno/08-0218/
« Last Edit: April 11, 2011, 08:16:21 AM by flybox1 »
Offline jneuf
« Reply #8 on: April 11, 2011, 09:06:33 AM »
That is a genius product! I'm ordering those now!
'75 CB400f
