Author Topic: Engine Casings and Cam Chains  (Read 2233 times)
Offline nigelrharris
« on: April 11, 2011, 09:05:01 AM »
Hi This is my first post here,
I have 2 questions I would very, much appreciate some help with please.
1.   See attached pic. You will see the the 8mm head bolts have fractured the bottom of the threaded hole after torqueing up to the correct setting. This may well be due to that fact that I had the head skimmed as the torque settings were correct and the washers were in place.
In your opinion can this be left as is or would it need to be welded up?
I will add thicker washers when I re-torque it to prevent further damage.
2.   How do you decide if the cam chain needs replacement? The Haynes manual describes a method that requires 4 hands, and seems to be the most complicated way to achieve a definitive answer. Has anyone a better way as I don’t want to buy a new cam chain needlessly.
Thank you for reading my questions and taking the time to answer them
Nige
Offline Hope
  • How did I become an
  • SOHC member since '01
Re: Engine Casings and Cam Chains
« Reply #1 on: April 11, 2011, 09:40:21 AM »
We don't see the attachment you reference in #1
As for #2, sometimes you can hear a cam chain rattle.  Definitely a sign that it is past due on changing.
« Reply #2 on: April 11, 2011, 12:39:12 PM »
I hope that these attach correctly this time
« Last Edit: April 11, 2011, 12:43:58 PM by nigelrharris »
Nige
