SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
cable routing
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: cable routing (Read 2728 times)
extek66
Full Member
cable routing
on:
April 13, 2011, 02:27:19 PM »
What is the correct routing for the throttle cables?I believe they go on the left side of the frame?Do they go above or below the tank mount and the coils?It is a 72 750.
Thanks John
Logged
Johnie
Really Old Timer ...
Re: cable routing
Reply #1 on:
April 13, 2011, 03:32:54 PM »
They go around the frame neck to the left as you said. Then under the tank mounts and under the coils.
Logged
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI USA
extek66
Full Member
Re: cable routing
Reply #2 on:
April 13, 2011, 05:02:51 PM »
Does the large wire harness go under the tank mount also?
Logged
Johnie
Re: cable routing
Reply #3 on:
April 13, 2011, 05:13:53 PM »
Wait...no. I just looked and I misspoke. The large harness goes over the tank mount on my K4. It is the same on my K1 too.
Last Edit: April 13, 2011, 05:17:29 PM by Johnie
Logged
Oshkosh, WI USA
Johnie
Re: cable routing
Reply #4 on:
April 13, 2011, 05:21:48 PM »
Here are a couple pics of my K1 which may help you out. Taken in front of the behind the coils. Click the pic to enlarge it...
Last Edit: April 13, 2011, 05:23:57 PM by Johnie
Logged
Oshkosh, WI USA
CycleRanger
No comment about being an
Central Texas Shop Manual Advocate
Re: cable routing
Reply #5 on:
April 13, 2011, 08:27:30 PM »
Great pix! Thanks!
Logged
CB750K5 '79 XL250s CL350K3
CB750K3 '76 XS650 '76 CJ360T
Toxic
Expert
Re: cable routing
Reply #6 on:
April 14, 2011, 04:20:42 AM »
Hey Johnie shouldn't your main cable bundle go to the inside of the throtle cables?
don't know the answer myself, just curious.
Logged
Johnie
Re: cable routing
Reply #7 on:
April 14, 2011, 05:38:23 AM »
Yah, I saw that but that is the way I bought it. When I tried it the other way it put to much of a bend in the throttle cables. And the harness was bent in a way to make the cables follow a smooth path.
Logged
Oshkosh, WI USA
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
cable routing
