Author Topic: double check my wiring schematic please...  (Read 1476 times)
Offline timdhawk
  • 1978 CB750K
« on: April 13, 2011, 06:31:26 PM »
Wiring a relay for the headlight. This is how I think it goes: (click on image to enlarge)
here's the stock wiring diagram:
Do I have this correct?
In deeper than I should be...
KingCustomCycles.com
Re: double check my wiring schematic please...
« Reply #1 on: April 14, 2011, 04:05:54 PM »
The third wire off the headlight should be a ground.  I gotta ask, why a relay at all?
Offline Bodi
« Reply #2 on: April 14, 2011, 07:53:37 PM »
The headlight will never go off. The relay coil will not get power (since the original HB and LB wires in the harness are from ignition switched power) so the relay contact will sit at 87a. You haven't switched the power feed labeled "fused" so the light is powered until the battery drains flat.
You want to cut the wire feeding the high/low headlight switch. Power the relay coil terminal 85 with the wire end from the HL fuse, ground 86. Run a new fused power wire from the battery to terminal 30 and connect the wire end from the high/low switch to terminal 87.
This will energize the relay when the ignition is on and maintain the starter headlight cutout. The headlight power draw will bypass the ignition switch and the wiring harness.
