Author Topic: aftermarket kickstands  (Read 1063 times)
Offline hondaface75
« on: April 14, 2011, 07:09:09 PM »
I have been searching and searching but cannot find a universal replacement kickstand. I dont want the ugly bracket or stock kickstand on the frame. I was looking for something that wouldnt maybe clamp onto the lower frame so I could position it where i want, but have not had any luck. Has anyone seen something like this, or made one of their own? I was thinking of making my own clamp and scavaging what I can off the old set up to make one.
Offline SOHC Digger
  • I'm not an
Re: aftermarket kickstands
« Reply #1 on: April 14, 2011, 07:48:36 PM »
Offline hondaface75
« Reply #2 on: April 15, 2011, 07:35:54 AM »
Ah! this is almost perfect. thanks! Ill get this and reweld the bracket to have a clamp on the end. I only worry about it slipping around the bar from the weight, but there is only one way to find out. Thanks again.
Offline q2418130103p
« Reply #3 on: April 15, 2011, 08:44:19 AM »
Why not weld this one to the frame?
Sent from my SAMSUNG-SGH-I897 using Tapatalk
Check out my CB550 project thread:
http://forums.sohc4.net/index.php?topic=83097
Offline hondaface75
« Reply #4 on: April 15, 2011, 10:10:38 AM »
The frame is painted and motor installed already. I know, not very bright. But I was certain I saw a clamp on verson of a kickstand on a photo somewhere here.  I suppose I could if it came to it. But I like the idea of being able to adjust it.
« Reply #5 on: April 15, 2011, 09:54:09 PM »
My BSA had a clamp-on kick stand, and no matter how hard I tightened the bolts, it would rotate if any real pressure was put on it. If you make your own clamp, make it very sturdy, spreading the load over a large area of the frame tube, using 4 clamping bolts.
Offline hondaface75
« Reply #6 on: April 16, 2011, 04:53:13 AM »
Yeah, i was going to try and model it after a set of nice highway pegs I have. Four allen head bolts with grooves on the bore, and the bore slightly smaller than the frame tube, so I can torque that bad boy right down. Only worries me because, the bike is kickstart only. Hell, even the stock kickstands I have are bent a bit.
« Reply #7 on: April 16, 2011, 05:12:00 AM »
Are you going to cut the old stand bracket off?
« Reply #8 on: April 16, 2011, 05:43:20 AM »
Virtually no clamp or modified clamp will hold that leverage. i'd drill it and the frame and peg it in place with bolts. 2 should do it. Though drilling the frame is not as preferable as welding, the whole thing is a compromise.
Offline hondaface75
« Reply #9 on: April 16, 2011, 08:35:57 AM »
 :-[ I was worried someone might say that. 2 bolts sounds good though. Some nice grade 8's maybe? Yes I already cut off the old bracket. That stand is impossible to put on without scratching the paint SOMEWHERE. I think Ill just go ahead and weld it. Dont want the bike falling over on me after all this work. Thanks for the help guys, Ill post back up when I get the part in and on the bike.
