Author Topic: Speedometer ratio for 75 CB750F  (Read 10930 times)
Offline jwk1414
« on: April 15, 2011, 02:13:03 PM »
I'm looking to upgrade to stock speedo/tach on my F to something a little sleeker.  I found this little guy on parts-n-more http://www.partsnmore.com/images/parts/480/03-0744.jpg (part #03-0744) and found out via their tech department that it runs at a 2:1 ratio.  I've been trying to find what the stock setup is on mine but haven't had any luck- any input on whether I could use this speedo?
Offline david 750f
  • 1976 CB750F
Re: Speedometer ratio for 75 CB750F
« Reply #1 on: April 15, 2011, 02:24:39 PM »
From the FAQ's.
CB750 Speedo  2240:60  Tach 4:1
CB650 Speedo  2240:60  Tach 4:1
CB550 Speedo  2240:60  Tach 20:3
CB500 Speedo  2240:60  Tach 20:3
CB400 Speedo  2240:60  Tach 20:3
CB350 Speedo  2240:60  Tach 20:3
Edit....I believe the three most common speedo ratio's are 1:1, 2:1 and the 2240:60.
« Last Edit: April 15, 2011, 05:51:11 PM by david 750F »
1976 CB 750F
Offline jwk1414
« Reply #2 on: April 15, 2011, 02:34:00 PM »
ahh. don't i feel silly now.... Thanks David.
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #3 on: April 16, 2011, 01:35:25 PM »
am feeling stupid now.....................what does the 2240:60 mean?
MATT
Offline geminimotors
« Reply #4 on: April 16, 2011, 05:21:19 PM »
37.33:1
Offline david 750f
  • 1976 CB750F
« Reply #5 on: April 16, 2011, 09:31:22 PM »
I believe it means 2240 rpm at 60mph.. If you do the math it works out to approximately 1.7:1.
The easiest way to check would be to rotate the front wheel once and see how many times the speedo cable rotates..
1976 CB 750F
Offline Dusthawk
  • Dusthawk & Rita IFO Phils Cafe, bestest Breakfast!
    • My MySpace Place
« Reply #6 on: April 17, 2011, 02:13:15 AM »
Thank you for this info, I asked for Tach ratios in a thread last week but this answers it for me.
1971 Honda CB750 K1 Chopper A.K.A. Rita
Build Thread: http://forums.sohc4.net/index.php?topic=86383.25
« Reply #7 on: April 17, 2011, 08:00:20 AM »
Cyclerecycle sells those speedos and tachs in the ratios we need, but some are out of stock. http://www.crc2onlinecatalog.com/Index_Main_Frame.htm
