Author Topic: CB750 engine serial numbers  (Read 12204 times)
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« on: April 15, 2011, 04:31:50 PM »
I just picked up a parts bike with a pretty slamming engine.  It's a 750, but I'm having a hard time figuring the exact year. The engine has the number CB750E-25xxxxx.
I thought it was a 1976, but all the charts I see list '75 as 24xxxx and then don't list anything until 27xxxx in 1977. Does this number say it's a 1976????
Thanks so much.
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline Gordon
  • 750K1, 550K2
Re: CB750 engine serial numbers
« Reply #1 on: April 15, 2011, 05:35:07 PM »
Did you see this chart on sohc4.net?
http://www.sohc4.net/index.php/archives/111
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #2 on: April 15, 2011, 05:43:36 PM »
Yep. That's what I was going off. Also checked on cycle chaos. Am I missing something here?  There is no mention of 25xxxx at all. It goes from 24xxxxx to 27xxxxx. There is also on year that appears to be left blank.
~Sophocles
Offline david 750f
  • 1976 CB750F
« Reply #3 on: April 15, 2011, 05:53:57 PM »
The 25***** engine numbers are from the 1976 F1's. You probably have an F motor.
http://www.sohc4.net/index.php/archives/36
« Last Edit: April 15, 2011, 05:55:29 PM by david 750F »
1976 CB 750F
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #4 on: April 15, 2011, 06:23:43 PM »
Thanks guys. The only thing that confuses me is that there is no F before the E in the serial number. I saw that 25xxxx was listed for the F - and I assumed that was it, but when I double checked, I saw that my serial is: CB750E 25xxxxx
~Sophocles
Offline david 750f
  • 1976 CB750F
« Reply #5 on: April 15, 2011, 08:58:55 PM »
Nortstudio, no F in my engine serial number. It is definitely the original engine.
I have not seen a CB750F engine with the letter F in the engine serial number.
I just checked my original Honda parts list for my 1976 CB750F and they show a F in the VIN number but not for the engine.
David
« Last Edit: April 15, 2011, 09:01:39 PM by david 750F »
1976 CB 750F
« Reply #6 on: April 15, 2011, 09:26:30 PM »
Nort - what are you going to do w/that motor?
Offline CycleRanger
  • No comment about being an
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #8 on: April 16, 2011, 03:50:34 AM »
Awesome, thanks guys.  I think it was cycle chaos that threw me off, mentioning the FE preceding the numbers.  Sorry to be a pain....
The whole thing is being sold (except for a very few odds and ends that I will keep for myself).
Tango has dibs on some of the stuff, but I will be listing it all here first, as soon as I can get photos up.
~Sophocles
« Reply #9 on: April 16, 2011, 09:15:32 PM »
Being that you did not know what it was, what makes it a "slamming" engine ??
 Does it have studs on the exhaust ports..?
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #10 on: April 17, 2011, 04:17:57 AM »
Good point, I should have been more specific.  I meant "looks" slamming.  It's about 75% cleaner than the way the engine on the '76 550 Looked when I first got it. I should have said it looks clean.
I was pretty sure I knew what I had - but the confusion came from the listing of an engine number with an F in it, on the cycle chaos site.  And although I have not dug into it yet, I have high hopes....
« Last Edit: April 17, 2011, 04:39:34 AM by Nortstudio »
~Sophocles
