Author Topic: Scored me a 750F frame :)  (Read 1393 times)
Offline 78 k550
« on: April 12, 2006, 05:59:41 PM »
Hey All,
 I'm really thinking hard on this one. The local yard has a couple 750F's there checking on another with a motor. This one they have a title for is a 75 I think. Frame seat pan and fender, front forks. $150.00 Or a little more for the one with the motor. They said they have a builder motor (black) for a couple hundred. I'm wanting this thing as naked as can be. I'm looking to not spend more than 800-1000 on this project. As long as I have a titled frame The rest is easy.
 So it look's liike I'll be trading some parts  :) for my 750.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Re: Scored me a 750F frame :)
« Reply #1 on: April 13, 2006, 03:55:45 PM »
 Make sure it isn't an F2 engine.
Offline GroovieGhoulie
  • I have to return some videotapes.
« Reply #2 on: April 13, 2006, 04:02:01 PM »
What's wrong with the F2 engine?  I thought they were better since they had hotter cams and put out more power stock?
« Reply #3 on: April 14, 2006, 11:53:33 AM »
The valve train is the problem. Excessive guide wear, valve stem tip damage, crappy retainer/keeper set up, new valves aren't available from Honda etc.
« Reply #4 on: April 14, 2006, 12:28:52 PM »
Ah.. I see.  Could one take an F2 engine and drop different heads on it, keeping the original cam?
Offline 78 k550
« Reply #5 on: April 14, 2006, 06:17:08 PM »
F2 meaning 78?
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #6 on: April 15, 2006, 05:30:31 AM »
« Reply #7 on: April 15, 2006, 05:32:24 AM »
Not quite that easy. It results in too much compression because of chamber volume differences. It's been discussed many times on the tech board.
