Author Topic: Front Disc Brake Rotor For Comstar Wheel On 77' CB550K  (Read 1681 times)
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« on: April 12, 2006, 08:39:07 PM »
          I'm trying to get a pair of Comstar wheels lined out on my 77' CB550K Project and the problem
    right now is, the rotor is too close to the fork leg. I've heard of another Honda rotor that will work
    but, I don't remember which one. I'm not sure about the sprocket line up because the engine is
    apart at the present time. If I get to the rear wheel and the sprocket situation before I get the
    engine ready(which I probably will), then I have a 500 engine I can hang it there to use for the line
    up of the sprockets. I am only assembling the bike to check the fit and alignment anyway (for now)
    If anyone has input on these things I've mentioned, feel free to jump in at any time. I have a 78'
    CB550K that I'm going to build with Spoke wheels but, I want Comstars on the 77'. Later on, Bill
Member # 1969
Offline cb650
Re: Front Disc Brake Rotor For Comstar Wheel On 77' CB550K
« Reply #1 on: April 13, 2006, 03:51:54 AM »
Did you try the 550 rotor?   Maybe it has less of a dish.   Might have to redrill holes if everything else checks out.
Did you get that tank?
              Terry
Offline bill440cars
« Reply #2 on: April 13, 2006, 05:12:07 AM »
              The disc on the CB650 Comstar wheel has 5 mount holes and the 450,500 & 550 has 6
         holes. I was thinking that I had seen, on this site, someone who talked about using the rotor
         from a CB200T or something like that. I know that someone, on this site, has put Comstars on
         either a CB500 or 550 (both the same) and I sure could use some input. I'd hate to think that
         I'd have to redrill the mount holes but, I guess we'll see. The disc needs to be flatter than the
         650 disc.
                No, I took another look at the photo that showed the tank from the rear,after what you
          said, and realized that it was pretty wide at the rear. I like the teardrop shape from the side
          but, it would need to be tapered more from front to the rear and that one wasn't.
                Oh well, the search continues on. Thanks for your response and I'm glad you brought
          that out about that tank. If it hadn't been for you, I might have ended up with a gas tank
          that would end up sitting on a shelf.
                                                          Later on Terry,      Bill :) ;)
Member # 1969
etn4runner
« Reply #3 on: April 21, 2006, 03:53:31 PM »
i need to know the exact same thing. I have 77 550f that i want to run comstars on. If i can't find what im looking for a may just swap the whole front end for an f2.
Offline cb650
« Reply #4 on: April 21, 2006, 06:06:23 PM »
 I know what Bill has as a comstar but everyone else remenber they made 3 diff comstars.  At least.
Bill if you want a 650 tank to try let me know.
                      Terry
Offline bill440cars
« Reply #5 on: April 21, 2006, 06:24:16 PM »
               Thanks Terry, I may do that and I may need to get with you on the rotor thing also.
       I'll probably PM you early next week about that and the rotor deal. Catch you later, Bill
                And for the record guys, My comstars are the black ones on of a 79' (I think) CB650.
        I knew of 2 different kinds myself. My CB400F has a silver set with what look like actual spokes.
        So, that being said, now does anyone know of a brake rotor that is more shallow than a CB650
        rotor and is mounted with 5 bolts?
« Last Edit: April 21, 2006, 06:33:03 PM by bill440cars »
Member # 1969
