Author Topic: Oil leak from left cover on CB400f  (Read 1420 times)
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« on: April 17, 2011, 06:41:13 AM »
Got back from a run on my CB400f today and oil is leaking from the alternator cover, where the wiring loom comes out, I assume it is from the crank oil seal, will strip it out tomorrow to confirm. Is it possible to change the seal with engine in the frame or does the crankcase have to be split? Anything else that could cause a leak in this area?
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline steven400/4
  • tyre inspector
  • that nice
Re: Oil leak from left cover on CB400f
« Reply #1 on: April 17, 2011, 11:28:30 AM »
i have new seal here if you need it mate
1978 honda 400/4 f2 my baby
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #2 on: April 18, 2011, 08:27:13 AM »
Had a look today, there is nothing from the crank seal, maybe a little dampness from the oil passage plug, the leak I saw is from the oil pressure light switch.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline steven400/4
  • tyre inspector
  • that nice
« Reply #3 on: April 18, 2011, 12:21:36 PM »
i,ve got some pressure switches if you need one not new tho
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #4 on: April 18, 2011, 12:29:22 PM »
Thanks Steve, I've got a used one too will give it a try first. The failed one is leaking around plastic where the wire connector fits.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline steven400/4
  • tyre inspector
  • that nice
« Reply #5 on: April 18, 2011, 01:22:19 PM »
ok malc buzz me if you need one
