Author Topic: it started life as a Test-rig  (Read 30756 times)
Re: Test-rig
« Reply #125 on: May 30, 2012, 04:25:30 pm »
Ok, another one. With this I need your help:
Tonnie hard charging to stay ahaed of the 1000cc Laverda of the Gijs van Dijk Team which won the demo (race).
Need to put more speed in the bike for the coming edition.
Good pics Rob. I'm also not surprised to read the statement above.  ;)  ;D
Offline voxonda
Re: Test-rig
« Reply #126 on: May 31, 2012, 03:29:50 am »
Hey Brent,
You know what I am talking about. You start with something and before you know it you're in to your neck in it. I just need that little extra to give to the guys, and myself of course, to keep up with the fast(er) bikes. Not much but a little. On braking and cornering/steering we are (more than) a match, but all out speed.......
Will first put her on a dyno to see were we are and go from there.
Cheers, Rob
« Last Edit: May 31, 2012, 03:46:01 am by voxonda »
  • Moderator
Re: Test-rig
« Reply #127 on: May 31, 2012, 05:02:19 am »
Rob, what was the longest straight and what was the entry speed ?
Also, what speed were they reaching on the long straight ? (MPH please.)
Sam. ;)
Offline voxonda
Re: Test-rig
« Reply #128 on: May 31, 2012, 05:23:20 am »
Sam,
Honestly for most I have no clue! But..............straight is about 600 meters long and the bike hit 9000rpm in fifth.
Rob.
Offline romerider153
Re: Test-rig
« Reply #129 on: May 31, 2012, 10:29:45 am »
does the other side of your oil cooler route directly back to the top of the oil tank so in essence you just plumbed it inline to to your oil tank return line?
Offline voxonda
Re: Test-rig
« Reply #130 on: May 31, 2012, 11:38:26 am »
That is correct.
Offline voxonda
Re: Test-rig
« Reply #131 on: May 31, 2012, 11:48:47 am »
Got a lot of compliments on the sound and speed of the bike, see what you think.
« Last Edit: May 31, 2012, 11:50:36 am by voxonda »
Offline wannabridin
  • Patience made me a
  • -Garrett
Test-rig
« Reply #132 on: May 31, 2012, 10:22:05 pm »
Now that's how a 750/4 should sound!!  Tip of the hat to you Rob, GREAT bike !!  Wish I could see it in person
Re: Test-rig
« Reply #133 on: June 01, 2012, 07:46:20 pm »
Nothing sounds quite like a good Honda four.... ;)
Offline voxonda
Re: Test-rig
« Reply #134 on: August 05, 2012, 11:11:51 am »
Very busy with preppin' for the trip to the Isle of Man and work that is lying around. In the mean time been working on both the racebikes. Fitted the 'test-rig' with a box swing and wire wheels, so she's ready to do battle again.
Been working on the Japauto replica too. Changed the oem swing for a longer F2 one, and changed the rearbrake arrangement. Made the 'new' Brembo caliper floating with the reaction arm to the frame.
Need to mill the caliperhanger to get rid of the excess material.
« Last Edit: August 05, 2012, 11:14:19 am by voxonda »
Offline mec
Re: Test-rig
« Reply #135 on: August 05, 2012, 12:42:40 pm »
why? for the look or to reduce unsprung weight?
to reduce unsprung weight its easier to mount the springs of your shocks upside down :) :)
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline voxonda
Re: Test-rig
« Reply #136 on: August 05, 2012, 12:47:56 pm »
mec
As you can see in the pic there is some excess weight on the hanger where the reaction arm used to be attached, that mateiral I need to remove. I know about unsprung weight but you cant mount these shocks upside down.
Rob
Offline mec
Re: Test-rig
« Reply #137 on: August 05, 2012, 01:20:10 pm »
mec
Rob
you can mount the springs upside down.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline voxonda
Re: Test-rig
« Reply #138 on: August 05, 2012, 01:30:25 pm »
Sorry mec,
Misread it. Yes, the spring can be mounted upside down. Try that when I'm spraying the shocks. Thnx for the idea.
Rob
« Last Edit: August 05, 2012, 02:43:38 pm by voxonda »
Offline wannabridin
  • -Garrett
Re: Test-rig
« Reply #139 on: August 05, 2012, 09:11:59 pm »
looking good Rob!!  can't wait to see/hear it again in a video!
check your PM's, i inquired about a triple tree  :D
Offline turboguzzi
Re: Test-rig
« Reply #140 on: August 06, 2012, 02:39:15 am »
Sorry mec,
Rob
not many pay attention to this but with the shocks mounted the way you did, essentially the piston is working most of the time in the area where the air volume is = not good for damping. you will get much more consistent damping (good for the TT i guess) by mounting the shocks with the hydraulic cylinder on top so the piston is always working fully submerged. it did made a nice difference in my bike but i agree that the honda shock mounting system is a b@%^ to reverse
Offline voxonda
Re: Test-rig
« Reply #141 on: August 11, 2012, 10:37:15 am »
After examening the bike and studying pic's off several demo runs we entered come to the conclusion we need more ground clearance. Bike is steering very well and has grip. despite not using real racing tyres but, tho very good, normal BT45's. Could use a somewhat wider rim/tyre combo. Bike is already raised about 1" higher than 'normal'.
When we get a little 'overboard' think we'll be having a prob with the alternatorcover grinding thru.
Any suggestions?
Thnx, Rob
« Last Edit: August 11, 2012, 10:40:33 am by voxonda »
Re: Test-rig
« Reply #142 on: August 11, 2012, 11:24:23 am »
 Total oss ignition, magneto, or remote belt driven alternator...
Offline voxonda
Re: Test-rig
« Reply #143 on: August 11, 2012, 12:18:46 pm »
First two no option in 3 hour races. belt driven alternator on the other hand..........................
Thanks 754.
Offline mec
Re: Test-rig
« Reply #144 on: August 11, 2012, 12:59:36 pm »
is it a must to run with (front) light?
do some mathematics, maybe a lightweight LiFe batt is an option.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Re: Test-rig
« Reply #145 on: August 12, 2012, 07:58:25 am »
 I think KUBOTA makes a small alternator, if you visit a rewind place, ask about the smallest they know of.
 Then you can mount off the crank snout run Alt, inboard or outboard, ahead or behind motor using a toothed belt.
 cover your  cranksnout, and seal up the oiling, and have gobs of ground clearance.
 The starter clutch oil hole should be blocked off, I push on a sleeve with a flange (for install, and removal) If you run a flat block off plate, run a floating seal reatainer outside of that. I used 2.5 OD aluminum by about 5/8 thick, with a 1 inch ID seal (remember, I have a thin sleeve over the oil hole). By using 1/64" over holes in my seal plate, it lines itself up to the cranksnout, and position of the flat blockoff plate, does not need to be precision drilled and dowelled..
 I found out the hard way, after I missed a race, I spent about 8 days getting ready for...
Offline voxonda
Re: Test-rig
« Reply #146 on: August 12, 2012, 08:05:00 am »
Tnx 754, will look into that.
Cheers, Rob
Re: Test-rig
« Reply #147 on: August 12, 2012, 04:32:05 pm »
Here's a couple of pics of a Kubota alternator. If I recall correctly, this is a 25 amp model. These have an internal rectifier and regulator. You will need to wire a small light in series with the switched ignition lead, to tell the reg when to energize the field (this also acts as an idiot light). The units are made by ND, I think.
« Last Edit: August 12, 2012, 06:24:23 pm by scottly »
Offline Old Scrambler
Re: Test-rig
« Reply #148 on: August 12, 2012, 05:30:05 pm »
http://cyclexchange.net/Elec%20System%20Comp%20Page.htm
I don't personally know if this works.........Ken has several 'test mules' in action.
Do you use both headlights at the same time or is one a backup?  Could they be lower wattage?
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Tintop
Re: Test-rig
« Reply #149 on: August 12, 2012, 06:07:06 pm »
You might want to check into one of these Rob.  I'm using a three phase version (modified for the XS) on my sidecar.  Similar to the CycleX product but with more output.
http://www.tri-corengland.com/acatalog/Three-Phase-210-Watt-Alternator-Kit-SPX003.html
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
