Author Topic: it started life as a Test-rig  (Read 30749 times)
Offline voxonda
Re: Test-rig
« Reply #175 on: September 22, 2012, 01:01:08 pm »
Thnxs 754,
Idler will be moveable by excentric, so can change tension or remove belt easy.
Re: Test-rig
« Reply #176 on: September 22, 2012, 01:19:57 pm »
Good dragracing trick..
Offline voxonda
Re: Test-rig
« Reply #177 on: January 10, 2013, 07:53:32 am »
Finally managed to finish the remote alternator,
Am pleased with the outcome.
  • Moderator
Re: Test-rig
« Reply #178 on: January 10, 2013, 08:19:53 am »
Well done young Rob, very neat indeed. :o :o :o :o :o :o :o
Sam. ;)
Offline Bill/BentON Racing
    • BentON Racing
Re: Test-rig
« Reply #179 on: January 10, 2013, 08:20:57 am »
You should be...way cool! Trade for rods? lol!!!!! ;) ;D
Rob,I'll PM more info.Bill
BentON Racing Website
BentON Racing Facebook
Offline MondayLSR
Re: Test-rig
« Reply #180 on: January 10, 2013, 10:09:54 am »
Wow!  very cool!
Whats the reasoning/benefit to using that alternator setup over stock?
Re: Test-rig
« Reply #181 on: January 10, 2013, 11:11:47 am »
Wow!  very cool!
Yes it really!
To your question, to go fast guys like Rob, they need that ground clearance on the left side. Allows fairing to tuck in.
Any other reason, Rob?
Re: Test-rig
« Reply #182 on: January 10, 2013, 11:37:47 am »
That's a nice trick set-up Rob, great job.
Will there be kit's available?  ;D You knew someone would ask.
Offline voxonda
Re: Test-rig
« Reply #183 on: January 10, 2013, 11:39:15 am »
Main reason is ground clearance:
Other is that the oem alternator is 40 yrs of age. The one I use here is much younger, has the rectifier inside, etc.
« Last Edit: January 10, 2013, 11:40:54 am by voxonda »
Offline voxonda
Re: Test-rig
« Reply #184 on: January 10, 2013, 11:42:36 am »
Thanks Guys, yes if there is demand kit's will be made available.
Cheers, Rob
Re: Test-rig
« Reply #185 on: January 10, 2013, 11:52:33 am »
Cheers, Rob
So would that be a streetable mod? Run in the rain, drive a headlight and charge the battery? Or is it ignition only?
Offline voxonda
Re: Test-rig
« Reply #186 on: January 10, 2013, 12:06:57 pm »
Would be 100% streetable mod. I use it on this endurance racer, and thus rain, lights etc all needed.
Re: Test-rig
« Reply #187 on: January 10, 2013, 12:22:44 pm »
Yikes! I'm in, sort of, depending on price. But I'm comparing it to the CR750 setup KOS was selling some time ago. So probably your price would be all right.
No hurry, distant project. But I'm very interested.
Re: Test-rig
« Reply #188 on: January 10, 2013, 01:24:51 pm »
Nicer work as usual Rob... ;D ;)
PS, hope you had a great Christmas and New Year mate... ;)
Offline voxonda
Re: Test-rig
« Reply #189 on: January 10, 2013, 02:01:15 pm »
Hey Mick,
Thanks. Had some wonderful Holidays, hope you had too.
Cheers mate.
Offline Tintop
Re: Test-rig
« Reply #190 on: January 10, 2013, 06:58:34 pm »
Very nice Rob, should do the trick and doesn't have any hard to find / replace parts.  Just what you want on a race bike.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Re: Test-rig
« Reply #191 on: January 10, 2013, 07:09:25 pm »
Rob, you might want to consider adding some thin flanges to the outside edge of the pulleys to prevent the belt from "walking off". Any idea of power output at idle speeds? I forgot what size alternator you settled on..
Offline voxonda
Re: Test-rig
« Reply #192 on: January 10, 2013, 11:34:53 pm »
Thanks again,
@Scottly: I can add flanges to the pulleys if necessary. But if all is lined out properly it wont be an issue. As soon as the bike is running again we'll know. Power output at idle should not be a problem since this is a alternator used on earlier Suzuki's.
Offline Tintop
Re: Test-rig
« Reply #193 on: January 11, 2013, 06:41:06 pm »
Are you going to put a cover / guard over the all, or part of it Rob?  Would think tech would require it, just like a belt drive on a BSA / Norton / Triumph.  Something to protect the crank end would probably be a good idea anyway.
77 CB550 Cafe build
    • BentON Racing
Re: Test-rig
« Reply #194 on: January 11, 2013, 07:08:15 pm »
A clear one!!!! ;D Bill
Re: Test-rig
« Reply #195 on: January 11, 2013, 10:51:01 pm »
 Like this ?
 Nice work , Vox..
« Last Edit: January 11, 2013, 10:52:53 pm by 754 »
Offline voxonda
Re: Test-rig
« Reply #196 on: January 12, 2013, 02:40:07 am »
Whole assembly will be covered. Crank will get extra protection. Will show shortly.
ccmclane
Re: Test-rig
« Reply #197 on: January 12, 2013, 04:01:01 am »
Voxonda,
That is some very inspiring engineering!
Like this ?
754,
What is that mounted on the crank?  And are those a pair of DCOE's?
(love the chopper btw)
Re: Test-rig
« Reply #198 on: January 12, 2013, 08:54:33 am »
 I put a sleeve over the oil hole and made that round cover to hold the seal, then the end piece to somewhat protect it. My buddy was crying that the end had to be covered, I said I amnot that worried about it. 30mm throats in those DCOE,s.. I got those in the late 70,s
Offline voxonda
Re: Test-rig
« Reply #199 on: January 12, 2013, 11:44:56 am »
In order to improve on the aerodynamics ordered a Rickman style tophalf fairing. Should give us some advantage on top. ( I hope)
Sure does look nice.
