Author Topic: blinker blowing main fuse  (Read 1699 times)
Offline lefty2023
« on: April 17, 2011, 05:52:39 pm »
its a stock 77 cb550k.  i just charged the battery and let it sit for a few hours, it check out at 12.55 volts.  i put the battery in  the bike turn the ignition on but not running and the voltage starts at 12.55 v and counts down slowly.  i turn the left blinker on and it works perfect, front and rear bulb light and flash accordingly.  as soon as i turn it to the right blinker the main 15 amp fuse blows. i recently went through almost every wire and clean them. i have no loose wires that i know of.  any suggestions on where to start with this?
also, is the rear brake light housing sealed?  i didnt want to come off when i tried removing it and i didnt want to crack it.
77 cb550k and 77 cb550f
Offline MoMo
  • Ride like you're invisible
Re: blinker blowing main fuse
« Reply #1 on: April 17, 2011, 05:57:49 pm »
You need to check the light blue wires for the right turn signal, make sure that there is not a short in the front or rear.  If the system worked before you cleaned the wires, there is a chance you made a mistake reconnecting, but pay attention to light blue...Larry
Offline lefty2023
« Reply #2 on: April 17, 2011, 06:42:36 pm »
I have a solid black and a solid green wire coming from the right blinker. Also when I cleaned my contacts I did not go into the rear blinkers or brake light
Offline DarcyCB400F
« Reply #3 on: April 17, 2011, 06:48:02 pm »
You need to check the wires for the right turn signal, make sure that there is not a short in the front or rear.  If the system worked before you cleaned the wires, there is a chance you made a mistake reconnecting, but pay attention to ...Larry
+1 Larry!
Question?? What has recently changed? Why is the right signal now not working/blowing fuses? What work have you recently done on the bike - electrical or not - or is this a new bike to you? Some background info would sure help with solutions.
1977 CJ360T
1977 CB400F
1980 CB900 Custom
1981 GS550L
1989 DR200R
1998 VT1100C2 ACE
1999 XR400R
2006 CR230F
2007 HD Road King
Offline lefty2023
« Reply #4 on: April 17, 2011, 06:58:46 pm »
alright i made some progress.  i found that one of the wires coming from the front right blinker was pinched under one of the pieces that holds the fork tubes and the wire was exposed and grounded.  i wrapped it with electrical tape and NOW i dont blow a fuse when i turn on the right blinker BUT the rear right blinker only flashes, the front right does not flash.
as far as recent changes are on the bike.....i did adjust  my voltage regulator over the winter time to help with charging.....ive replaced my fuse holder from a doner bike.....thats about it.
Offline DarcyCB400F
« Reply #5 on: April 17, 2011, 07:12:39 pm »
Great news? Any idea how that wire got pinched?
Simpleton question... have you tested or replaced with a known working bulb with the bulb that isn't flashing?
Does it even light up as it should as a running light?
1977 CJ360T
1977 CB400F
1980 CB900 Custom
1981 GS550L
1989 DR200R
1998 VT1100C2 ACE
1999 XR400R
2006 CR230F
2007 HD Road King
Offline Gaither
  • '77 CB550F
« Reply #6 on: April 17, 2011, 07:21:34 pm »
Lefty
Turn sigs need a good ground or they will do crazy things.
I "lost" the LF turn sig. I was told here to run a "Popwood Ground". I did so (very easy to do) and haven't had any more trouble with the turn sigs.
Just a thought for a possibility.
Gaither ('77 CB550F)
Offline lefty2023
« Reply #7 on: April 17, 2011, 07:40:33 pm »
Ok I'll look into doing that. Yes I have swapped bulbs,  The running lights work so obviously the bulb isn't toast and it was pinched because there was too much slack in the wire
