Author Topic: Speedometer drive assy won't stay put!  (Read 500 times)
Offline Lavis500
  • Why don't you go ask a
  • "Don't plan vast projects with half-vast ideas"
« on: April 17, 2011, 08:30:21 PM »
After torquing down my front end on my 500K2, I've realized that my speedo drive moves with my wheel.  Once it touches part of the fork it obviously stops moving.  I just replaced my wheel bearings, and I'd say that I get about 1.5 turns out of the front wheel on a good hard push.  Is something else other than the torque of the axle supposed to hold this in place?  I don't remember disassembling anything else...   ???
"Whatever it is, I swear I didn't do it!"
'73 CB500 - Sally
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
Re: Speedometer drive assy won't stay put!
« Reply #1 on: April 17, 2011, 09:11:47 PM »
I seem to remember that the drive just sort of floats around, but once the cable is attached it finds its home position and stays put.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Lavis500
« Reply #2 on: April 17, 2011, 09:19:47 PM »
Okay.  It just seems weird  to me that it would be semi-free floating.  I guess I'll see how different it is once I put the cable in, but that won't be until after I button up my engine and mount it.  Thanks for making sure I'm not crazy! ::)
'73 CB500 - Sally
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: April 17, 2011, 10:30:50 PM »
Don't know about the 500, but on both the 550 and 750 the speedo drive is not free-floating.  Once you screw the axle tight it stays put.  I'm pretty sure the 500 should be the same.
