Author Topic: Use of Multi-level steel (MLS) head gasket on CB 750 K1  (Read 1231 times)
Offline Rob750k1
« on: April 20, 2011, 06:47:20 AM »
Hello all--I am restoring a 1971 Honda CB 750 K1 motorcycle.  We are about to reassemble the motor, and one source recommended that we use a multi-level steel (“MLS”) head gasket, after the cylinder and head are decked and re-planed.  Apparently, MLS gaskets were not used on this model originally.  Do those in the know recommend this approach and if so, can anyone refer me to a source for the MLS gasket to fit this motorcycle?  Any other comments or suggestions would be appreciated.  Thanks, Rob Gibbs.
« Last Edit: April 20, 2011, 09:35:09 AM by Rob750k1 »
Rob
Re: Use of Multi-level steel (MLS) head gasket on CB 750 K1
« Reply #1 on: April 20, 2011, 12:03:59 PM »
These gaskets will be available very soon. The MLS stands for multi layer steel (you were pretty close ;))  Is this for a stock size bore?
« Last Edit: April 20, 2011, 12:05:41 PM by MRieck »
Offline Rob750k1
« Reply #2 on: April 26, 2011, 04:53:38 PM »
Yes, stock size bore.  Available soon?  From what source, do you know?  Thanks for your reply, MRieck.  Rob
Rob
« Reply #3 on: April 26, 2011, 11:54:58 PM »
Subscribed
Offline mickey6
« Reply #4 on: April 26, 2011, 11:58:47 PM »
+1 me too
76 cb750F in 7 boxes
73 cb500 daily cafe
Offline Skunk Stripe
« Reply #5 on: April 27, 2011, 08:33:52 AM »
Will they be cheaper or do a better job then a good cometic?
