Author Topic: Intake spigots needed! CR29s to fit CB750 F2 rubbers  (Read 3080 times)
Offline brandEn
« on: April 20, 2011, 06:42:51 PM »
Does anyone have some intake spigots that will fit CR29s to F2 rubbers? I need some so please help if you can.
« Last Edit: April 26, 2011, 08:32:48 AM by brandEn »
Offline Doctor_D
Re: CR special carbs on my CB750 F3- couple questions
« Reply #1 on: April 21, 2011, 06:44:14 AM »
Branden:
Meant to answer that question in your PM.  Yes, I have cable ends and a solder-pot to resize your cable.  No, I don't know how much needs to come off a stocker to work, as I found a Kwaka cable at Bent Bike that works out of the box (and would tell you what it was if I actually kept track of it  :-[ ).
Fuel line is easy.  Two different diameters of tygon are needed: a smaller line from the petcock to the filter and a larger one from the filter to the carbs. I'll give you mine on Friday, as my needs will likely change with the RS34's.
Take care,
David
1978 CX500
1971 Norton Commando
Offline brandEn
« Reply #2 on: April 21, 2011, 06:55:01 AM »
Awesome, thanks David. I ordered a bunch of jets and velocity stack screens. So with you donating your fuel line adapter I just need to get the throttle cable sorted. Hopefully someone will chime in about how much needs to be removed so I can put a cable end on while I am up there on Friday.
« Last Edit: April 21, 2011, 06:56:40 AM by brandEn »
Offline tweakin
  • tear down
« Reply #3 on: April 21, 2011, 07:01:54 AM »
Branden, You just mount the carbs, run your throttle cable back, then measure what needs to be cut off to fit.  Its that easy...
Offline brandEn
« Reply #4 on: April 21, 2011, 07:07:14 AM »
Thanks Tige. I guess I will have to do that and make two trips to Seattle then to use Davids solder pot.
Offline brandEn
Re: anyone have intake spigots for trade? CR special carbs on my CB750 F3
« Reply #5 on: April 22, 2011, 11:00:26 PM »
updated the first post. I need F2/F3 spigots. Can anyone help me out? Sudco wants over $200 for them!
« Last Edit: April 22, 2011, 11:06:26 PM by brandEn »
Offline Doctor_D
« Reply #6 on: April 23, 2011, 06:07:43 AM »
What about th spigots in the head?  Will my F carb boots fit?  If so - since I'm waiting on Mike to put the RS34's together - you can have mine.
I'll ride them down there to you around 10am if we can get an answer.
Take care,
David
1978 CX500
Offline brandEn
« Reply #7 on: April 23, 2011, 08:16:24 AM »
I would imagine the spigots in the head are to big for your boots. I am so bummed!
Offline tweakin
  • tear down
« Reply #8 on: April 23, 2011, 08:21:20 AM »
Simple mistake, but sucks...  Why don't you just return the carbs to Dave and order ones that fit?
Offline Doctor_D
« Reply #9 on: April 23, 2011, 08:26:28 AM »
Are the threaded adapters that screw-in to the carbs different for F2/F3 applications?  Is that the issue?
Take care,
David
1978 CX500
Offline brandEn
« Reply #10 on: April 23, 2011, 08:28:20 AM »
Yes bigger by about 3-4 mm I would guess.
Offline brandEn
Re: CR29 carbs on my CB750 F3- I need spigots for F2 rubbers
« Reply #11 on: April 26, 2011, 08:31:16 AM »
In desperate need of intake spigots that fit CR29s to F2 rubbers.
Offline Silverback
Re: Intake spigots needed! CR29s to fit CB750 F2 rubbers
« Reply #12 on: April 26, 2011, 12:04:16 PM »
So, you have CR specials that have the adapters for K boots, but you have F boots/rubbers??
The head side of the rubbers is the same, F or K. You can just use the K rubbers with your CRs. If you don't want to do this, I have seen a post somewhere on here describing how they enlarged the CR adapters to fit the F boots. They simply lathed some PVC pipe down to slip on the carb adapters and make up the couple mm difference.
Unfortunately, I haven't been able to get the search function to work very well for me so I can't find the thread.
OK! Found it!
http://forums.sohc4.net/index.php?topic=18570.0;nowap
« Last Edit: April 26, 2011, 12:08:42 PM by Silverback »
Chris
"It's hard to define soul. You get it in art. You get it in music, and occasionally you get it in machinery."
78 CB750F racer
78 CB750F stock
75 CB750K Baby Blue Sold (She was a great bike!)
71 CB750K (rusty rod)
77 cb550F Sold :(  Bought it Back :)
Basket case 73 CB750, 77 CB750F (Building now)
01 Aprilia Falco
76 kz400
96 BMW K1100LT
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #13 on: April 26, 2011, 12:43:34 PM »
Great tip and thanks for locating the link.
Offline brandEn
« Reply #14 on: April 26, 2011, 04:16:57 PM »
I don't have access to a lathe to make those adapters and even if I did I don't know how to use one. That is a great idea though. Thanks for the link. I didn't think I could use any other rubbers on my F head. I will have to look into that. Can anyone else confirm that early K rubbers will work?
Offline Silverback
« Reply #15 on: April 26, 2011, 04:58:02 PM »
I know this isn't necessarily a confirmation, but I have used F rubbers on just about every head except the F. :D
The difference in the rubbers is carb side to accommodate the PD carbs.
Chris
78 CB750F racer
78 CB750F stock
01 Aprilia Falco
76 kz400
96 BMW K1100LT
Offline brandEn
« Reply #16 on: April 26, 2011, 05:14:50 PM »
Thanks! Anyone got rubbers?
