Author Topic: Odd coil problem  (Read 1583 times)
Offline 68grandprix
Odd coil problem
« on: April 14, 2006, 12:53:56 PM »
A few weeks ago I bought a Dyna S ignition for my 75 Cb750 and installed it. After installation and timing I could tell the bike wasn't running right. I used the timing light to check that for spark. Cylinders 1-4 are fine. Cylinders 2-3 are both running at idle, but when I rev the bike cylinder 3 cuts out for a second and then comes back, and cylinder 2 completely quits and doesn't start sparking again until idle. When I first got the bike running (a year ago) cylinder 2 wouldn't run, and then it just started working. A couple months ago I started the bike for a ride and cylinder 2 wouldn't work for about 5 minutes, then it kicked in and ran fine. The coil tests fine, and I've checked all connections. Any ideas? I was just going to buy some Dyna coils, but I want to be sure the problem is the coil. Thanks, Jimmy
Offline Dusthawk
  • Dusthawk & Rita IFO Phils Cafe, bestest Breakfast!
    • My MySpace Place
Re: Odd coil problem
« Reply #1 on: April 14, 2006, 01:54:23 PM »
Sounds like coil to me, though it might also be the plug wires, a not so tight connection in the coil. Dyna coils are the bomb with the Dyna S so it'll work great. There are also some good threads regarding plugs, look for the Iridium. They are a bit pricy but complement the Dynas as well.
Peace,
Jeff
1971 Honda CB750 K1 Chopper A.K.A. Rita
Build Thread: http://forums.sohc4.net/index.php?topic=86383.25
Offline 68grandprix
« Reply #2 on: April 14, 2006, 02:10:52 PM »
Would the copper core (non suppression) wires work fine with the Dyna S? Thanks, Jimmy.
Offline scunny
  • don't call me expert
« Reply #3 on: April 14, 2006, 02:17:50 PM »
just swap your coils over, if the problem shifts to new cylinder then it's the coil
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline 68grandprix
« Reply #4 on: April 14, 2006, 02:46:59 PM »
I don't think the wires will reach, but I'll try. Thanks, Jimmy
Offline Rushoid
  • Shameless
« Reply #5 on: April 14, 2006, 10:57:20 PM »
You could try cutting the plug wire ends and reattaching the boots. That worked for me. Wait, no I replaced the boots. Anyway, worth a try.
Go Cards!! Go Colts!! Go Bucks!!
SOHC/4 Member #3452
