Author Topic: Clogged Brake Fluid Reservoir  (Read 2673 times)
Offline NorthWestYJ
« on: April 22, 2011, 10:29:37 AM »
Hello all!
I recently bought at 73 CB750 that hadn't ran since 94 and Ive been working on getting it ready to be licensed. One problem that I have not been able to figure out is how to un-clog the brake fluid reservoir it seems to be clogged with dried brake fluid.  I have tried rubbing alcohol and brake cleaner.  Anybody have any ideas?  Thank you!!
Offline NorthWestYJ
Re: Clogged Brake Fluid Reservoir
« Reply #1 on: April 24, 2011, 09:15:30 AM »
come on! no one has any ideas? not even a place to buy a new one?  I really need some help guys this is the last thing i need to get it on the road
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: April 24, 2011, 10:20:45 AM »
Are you saying the inside of the entire unit is covered in this, or just the small holes? I guess, in an act of desperation maybe boil it in some water.  ??? I have no idea if this would do anything beneficial, but then it is likely to do any harm either. I wouldn't use your SO's favorite pot though.  ;)
« Reply #3 on: April 24, 2011, 10:50:07 AM »
A coated reservoir presents no operational problems, save the pin point bleed hole nearest the brake line outlet.
That tiny hole must be cleared, yet remain tiny.  A narrow pin or needle can be used to clear it if you are careful.  I've also used the tiniest drill bit in the Xacto tiny drill bit set; #80.
However, there may also be a hard coating in the master's piston bore.  I remove this with aluminum oxide paper placed in the end of a wooden dowel that has had a slit cut in one end.  Then spin that in the bore with a drill.
Ensure that the bare piston without rubber bits can move freely in the bore, and you should be good to go for assembly and use.
Offline Tom in Newcastle......Ontario
  • Newcastle Ontario
« Reply #4 on: April 24, 2011, 10:52:47 AM »
Patience..........................
If the master is clogged with dried brake fluid ,what do the brake lines and caliper have in them......better check..
I have found that a Simple soak loosens up most or all of the dried and gooey remains
1978 cb 550k......stock,my first re-build
Loud pipes suck.......
If you buy something.........pay for it !
If you sell something .......ship it !
If you say you are going to do something......do it !
If you have a question about something......ask it !
When the seller answers ........let him know whether you still want it or not !
If you receive something .....let the seller know you got it !
If you get something and are happy/un happy with it .....let the giver/seller know !
If you have any kind of issue,shipping/receiving/quality/price/shipping charges etc !
Communicate
