Author Topic: 1974 carb "hard to find" rubber seal problem SOLVED!!  (Read 936 times)
nmbloke
« on: April 14, 2006, 07:16:22 PM »
All,  I solved my problem regarding the top rubber grommet looking seal that provides a dynamic sealing surface for the slide.  After searching all over the world from Keihin to desperation of failing ebay bids... I found a 11/32OD x 1/8 ID 3/16T rubber grommet at Lowe's.  I gingerly used a dremel tool to ream out the grommet.  It works perfectly!  No more issues trying to find a discontinued, cant find it anymore, good luck finding, look at you now-did you learn your lesson not to ever carb clean rubber bits part!
The manufacturer is Hillman.  Ahhh its nice to be back on the road again!
Offline 78 k550
Re: 1974 carb "hard to find" rubber seal problem SOLVED!!
« Reply #1 on: April 14, 2006, 08:43:47 PM »
great info and glad your on the road.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
